hi
im having trouble with the engine control unit in my car.
when i put a tester on it, does the unit not respond. so it would be very helpful if anybody have a pin diagram så i can check if the box are getting power or not.
i have the electrical diagram from the Haynes book, but it only shows pin numers of the control unit, but not the percision in the conectors.
best from
Charlotte
pin diagram for motor control unit
best from
Charlotte
peugeot 406 st. car 2.0 hdi
dw10 engine 2003
Charlotte
dw10 engine 2003
Re: pin diagram for motor control unit
Are any of the diagrams on here any use to you? viewtopic.php?f=10&t=20756#p206949
Thank you
but unfortunately it is not exacly what I was looking for.
in the Haynes Manual the diagram is marked with numbers on the sides of the manual control unit.
i have a picture of the 3 plugs this i marked by letters and numbers.
the problem is that i dont know what goes together. The control unit do not get any power and I would like to know where the trouble are.
best from
Charlotte
dw10 engine 2003
Charlotte
dw10 engine 2003
