And another small problem.....
Ady1985
2.2 16v
Post by Ady1985 »
Since I've had my 406 estate every so often it flashed up low brake fluid level, I've changed the front pads as they were worn down, brake fluid went back up as the pistons were pushed back on calipers and is on the max marker, It's still flashing low fluid, dodgy sensor?? And is it easy replaced?
Ady1985
2.2 16v
Re: And another small problem.....
Post by Ady1985 »
Balls, this needs to be moved to the brakes section I think
Ady1985
2.2 16v
Post by Ady1985 »
Oh and only does it when handbrake is applied or on
markw
Post by markw »
This is a common fault on Coupes and is normally rectified with a new switch under the handbrake. The fact you say it only does it when handbrake is applied sort of confirms it's the switch.
rwb
Post by rwb »
Known 'feature' with the handbrake switch. Try working the handbrake frantically. Yes, really.
There are posts about it on here, but it's not practical for me to find them as I'm on my phone.
Sent from my Samsung Galaxy SII that is out of contract and has reached it's auto-destruct date :roll:
Ady1985
2.2 16v
Post by Ady1985 »
Nice 1, I'll give it a go, are they hard to replace the switch?
markw
Post by markw »
Part no 6339-18 @ £4.49
The same switch is used in the glovebox btw if you're feeling particularly skint...... :oops: :)
Ady1985
2.2 16v
Post by Ady1985 »
Seriously!!?? [emoji54]
markw wrote:Part no 6339-18 @ £4.49
....or more readily recycled if your at the scrappy. :supafrisk:
Ady1985 wrote:Seriously!!?? [emoji54]
Oh yes indeed, according to Service Box anyway. A switch is a switch is a switch I guess
markw wrote:£4.49
even if they're made out of gold :roll:
Working the handbrake lever like an idiot for 20 seconds will see this fault vanish for months on end, the switch just gets dusty/fluffy/lazy it is a bit of a faff replacing it so if you can't be arsed just give the lever a workout (make sure no-one's watching you :oops: ).
Ady1985
2.2 16v
Post by Ady1985 »
Lmfao makes ya look like ya doing something very wrong very violently
markw
Post by markw »
steve_earwig wrote:
markw wrote:£4.49
For Peugeot, I thought that £4.49 was pretty reasonable Steve :cheesy: ......except that when you get the thing in your hand, it'll probably resemble something that started life in a Christmas cracker......
gumby6371
Post by gumby6371 »
Ady1985 wrote:Lmfao makes ya look like ya doing something very wrong very violently
Is this a case of...wait for it....
If you use your left hand it feels like someone else is doing it???
I'll get my coat
2003 2.2 HDI SE
Ady1985
2.2 16v
Post by Ady1985 »
Hahahaha I'll pick ya up lmfao
