Still leaking
Still leaking
Followed FarmerPugs lovely video tutorial on unblocking the sunroof drains today.
I used strimmer cord as I couldn't find anything else long enough and suitable (Used the thickest cord I could buy)
Took the hose out of the bottom, put it outside the drivers door like he does too... Pushed the strimmer cord as far in as I could get it... Felt like it went 3/4rds of the way down before it got stuck... Anyway, hot water down the hose later to free the dirt... Water happily flows out of the hose i.e no blockage.
However, and unfortunately I am still getting drips inside the car. The roof lining, in the corner near the sun visor is absolutely drenched, if I pressed it, it was like a sponge!
So, drain sorted - leak still persists.
Next course of action boys?
- Attachments
- (127.49 KiB) Downloaded 6 times
'Miss Pug' Peugeot 406 2.0 16v Petrol 'Family' Estate.
6th December 2011 - November 2014
24th January 2017 - Current (I bought her back!)
Re: Still leaking
Is the ariel above the interior light on this or is it at the rear of the roof ??
Re: Still leaking
On this one it's at the rear....trem1 wrote:Is the ariel above the interior light on this or is it at the rear of the roof ??
Re: Still leaking
Personally I would chop the funny bit of the end of the hose off,i cleared mine and it still leaks on occasions,i reckon the cross piece at the end of the hose goes brittle and it takes a lot of water to push past it and by that time it's backed up into the car,well that's my theory anyway and when I get a chance i'll be chopping mine off!
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: Still leaking
puts paid to that theory thenSonia406 wrote:On this one it's at the rear....trem1 wrote:Is the ariel above the interior light on this or is it at the rear of the roof ??
Re: Still leaking
I must admit I think that's a stupid design... but I took that off and the water flowed out nicely but still, drip drip on the inside... water is coming from somewhere else... is it at all possible the other end of the drain is detachable? The only thing I can think of myself is that the rubber hose has a rip / tear, what ever up nearer the sunroof?grasmere59 wrote:Personally I would chop the funny bit of the end of the hose off,i cleared mine and it still leaks on occasions,i reckon the cross piece at the end of the hose goes brittle and it takes a lot of water to push past it and by that time it's backed up into the car,well that's my theory anyway and when I get a chance i'll be chopping mine off!
Yeahtrem1 wrote:puts paid to that theory thenSonia406 wrote:On this one it's at the rear....trem1 wrote:Is the ariel above the interior light on this or is it at the rear of the roof ??
Re: Still leaking
It's always a possibility that someone in the past may have shoved something sharp down the outlet hole from the sunroof to clear it and damaged the hose
Re: Still leaking
Have you had a leaking sunroof and had to clear the drain?grasmere59 wrote:It's always a possibility that someone in the past may have shoved something sharp down the outlet hole from the sunroof to clear it and damaged the hose
I just wonder if your roof lining was wet in the corner, like a sponge?
Is it fairly easy to remove the hose all together to inspect it for holes, any idea?
Re: Still leaking
Mine leaks from both sides from time to time,mostly when going round corners but it only seems to drip from the alarm sensors,up to now the carpet has stayed dry and the roof lining is also dry,whenever possible I always park the car nose up and my drive is very steep so there's no way the water could run uphill to the front drain hoses.
Re: Still leaking
Ahhh - that'll be why you drive in not reverse in then... I had noticed that!grasmere59 wrote:Mine leaks from both sides from time to time,mostly when going round corners but it only seems to drip from the alarm sensors,up to now the carpet has stayed dry and the roof lining is also dry,whenever possible I always park the car nose up and my drive is very steep so there's no way the water could run uphill to the front drain hoses.
Must admit this chap said it only leaked while absolutely tipping down and only ever around corners but it seems much much worse than that....
Floor absolutely soaked, roof lining absolutely soaked like a sponge etc..
Re: Still leaking
To be honest though even on level ground in heavy rain it's only a few drips now and again,thats why I've never bothered trying to find the cause.
Re: Still leaking
Hi Sonia, my 306 sunroof drains are fine but water pours in still. I read on a 306 forum that the rivets that hold things in place near the rear of the sunroof can also let water through, although I haven't tested this theory yet.
Also, yes the tube can come away from the point where it joins the sunroof - resulting in cascades, literally cascades of water coming straight into the car. Turns out some idiot pushed a coat hanger through the drainage tube too hard and pushed the tube off the outlet completely. Only discovered when said idiot poured a kettle full over the sunroof to test it had cleared, what a twat.
My 406 occasionally drips by the alarm sensor things but I have checked my drains and they are fine - I assume its only condensation or something as it is minimal drippings...
Re: Still leaking
GingerMagic wrote:Hi Sonia, my 306 sunroof drains are fine but water pours in still. I read on a 306 forum that the rivets that hold things in place near the rear of the sunroof can also let water through, although I haven't tested this theory yet.
Sorry I laughed hard at that idiot lol:
I messaged FP last night and he too said about the rivets letting water in!
Must admit I did the kettle thing yesterday and still thought I saw it leaking..
We've had drizzle all night and drizzle this morning, got in the car, roof lining, alarm sensor and A pillar metal all dry - so maybe, just maybe... it's sorted itself out? I've kept the trim off the pillar at the moment to keep an eye on things...........
The roof lining yesterday was literally like a sponge.........
Re: Still leaking
I had leaks on mine.
When I pulled everything apart, there seemed to be a kink in the drainage pipe near
where it pushes onto th outlet from the sunroof.
I sorted that. Still leaked.
I checked where the aerial mounts onto the roof. Felt firmly fixed, and watertight.
Checked the top of the windscreen, outside.
There a little channel that runs the width of the screen. Behind that, flush against the body is a rubber lip.
That looked suspicious to me, so I bought some 'flowable silicon' screen sealer.
Ran a flat screwdriver along the length of the lip, with some kitchen towel inserted right behind it...
to clean out the gunge.
Then repeated the exercise, with the nozzle of the screen sealer inserted behind the screwdriver.
No more leaks, so far.
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
Re: Still leaking
trufflehunt wrote:I had leaks on mine.
That is really helpful to know... Did you find it wet at the top and just dripping down inside? Top corner of the roof lining soaked?
I will definitely be trying what you've suggested, thanks so much!
Must admit just took the car out again and did a corner with some speed and drip drip drip drip... but I felt the roof lining - still dry...... Confusing!
