How To: D9 Steering Wheel Removal and COM2000 Change
Knowledge Base Articles
Re: How To: D9 Steering Wheel Removal and COM2000 Change
No-one's got back to me on that one :( Providing it's not actually busted I *think* stretching the spring will do the trick but it seems a lot of work just to try it.
I bought myself a new COM2000 unit today and I'll be following this guide :)
Will let you know how I get on....
The last thing that he said was
Set this f*cker off
Best of luck! (It's a doddle, just a bit nervy)
All done! And I think I got rid of a rattles for good (as mentioned in the other thread) - lots of rags stuffed to stop metal-to-metal contact.
hamlex
Post by hamlex »
sorry to ressurect an old post but i stumbled upon this via google, along with the com2000 removal thread. since i dont want to fork out for a new one, i was all set to go and pull it apart tomorrow and have a go at stretching the spring, but im glad i read this thread now! think i'll give the sponge technique a try.
i suffer from the indicate-right-flicks-left problem. My father owned the vehicle previously and says its ONLY been doing this since it had the com2000 unit replaced by an official peugeot dealer! (whilst it was still under warranty). however, he was happy to leave it at the time, to save further faffing about. im pretty sure he asked them to check it the next time too but im not sure what happened there, i guess nothing.
So did everyone give up on repairing their com2000 units then?
2002 406 Estate LX HDi
There was a thread on here where wiggy was gutting the COM2000 unit. Don't think much came out of it though :|
Oops, I think I even approved your post Hamlex, then promptly forgot all about it :oops: If you didn't find the thread where I took one to bits it's here viewtopic.php?f=3&t=7635
As mentioned, I'm not really sure why they fail, it could be the spring going weak or it could be the ramp it pushes on - mine had a strangely rounded shape and I'm not sure if it was always like this or this was what it looks like worn. I stretched the spring on mine and it feels firmer but I'm reluctant to refit it to the car just to try it out. In all probability it'll work for a while, then the spring will collapse and it'll be back how it was. Perhaps it would be better to pack the spring out with something of equal diameter. It's a shame I'm not back in Blighty because (amongst many, many other things :( ) I'd enjoy getting a few of these to "post mortem".
Could be worth your while looking into it, possibly set up a nice little 'cottage industry' in remanufactured COMM2000's
Ah, but there's the customs / import / export problem. :roll:
With the price of these things, a return trip to Croatia's almost viable.
rwb
Post by rwb »
ServiceBox reports four different COM2000 units:
6242 30
01
CONTROL UNIT
VALEO
- W/O REAR SCREEN WASH WIPE AND WITHOUT ELECTRONIC STABILITY PROGRAM
6242 H6
01
DELPHI
- W/O REAR SCREEN WASH WIPE AND ELECTRONIC STABILITY PROGRAM
6242 C2
01
DELPHI
- REAR SCREEN WIPER AND WITHOUT ELECTRONIC STABILITY PROGRAM
6242 C6
01
DELPHI
- REAR SCREEN WIPER AND ELECTRONIC STABILITY PROGRAM
That be correct that be, depending on presence of rear wash/wipe and ESP. The ESP ones are the expensive ones...
grasmere59
Post by grasmere59 »
steve_earwig wrote:That be correct that be, depending on presence of rear wash/wipe and ESP. The ESP ones are the expensive ones...
Trust me to buy a car with esp fitted!! :(
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Do you have a floppy stalk then? :shock:
grasmere59
No i have an auto light system with a mind of it's own,i enables and disables whenever it feels like it every now and again and then behaves itself for ages then does it again,i suspect the button on the end of the lighting stalk on the comms 2000.
piglet
Post by piglet »
Just searched this dead thread out.
Only one bit of info missing:- what happens to the radio after (battery disconnection)
piglet wrote:Just searched this dead thread out.
do you mean does it loose its code, ?
Locked
