2.0 8v turbo ICV
2.0 8v turbo ICV
does anyone know when you twist the throttle does the icv inside open fast or slow as when i look down mine and rev the engine it opens slow and closes slow, im still having running problems with my engine and it seems like its not getting enough air.
Re: 2.0 8v turbo ICV
The ICV should close, not open when it's not idling. When you've got your foot on the gas, you're opening the main throttle butterfly which lets a hell of a lot more air through than the ICV
Any problems when running the engine with revs (not at idle) are almost certainly going to be nothing to do with the ICV.
- TRAVIS BICKLE
- 2.0 Turbo
Hey there matey, have you got this running right now? I've almost got together the parts needed to get mine put together. I'm using a xsara vtr base as I couldn't get a 306 cheap enough. I've got the full 406 loom, 306td subframe, hubs, driveshaft, rack. New td clutch, 306hdi box with td fork etc. So as soon as the new welder turns up i can crack on!
98, Executive turbo estate in aluminum silver. The stealth wagon! Now departed, New project Xsara VTR-8 in progress, Next Project, 406 D8 / JAP. So will be looking for a 406 again when the xsara is done!
- Site Admin & Mad Biker!
Have a read of this thread on ilexa.co.uk. There are some excellent tips that may be applicable!
Hi no not got this running correctly yet, still running like sh*t from cold start, gets warm and after running for a while the engine gets really boggy when you rev it ( like its running out of fuel) but soon as its cold again itl start up fine but soon go idle like the video. im going to try another coolant temp sensor incase i have the wrong one evan though its new it still could be! heres a decent video of my car idling in which you can hear its idling sh*t
http://www.youtube.com/watch?v=lyUDrlrN ... r_embedded
tried a new lamba as well, made no difference
i have tried 3 different icv's so mustnt be a problem there. cleaned all the earths a long time ago lol
- TRAVIS BICKLE
- 2.0 Turbo
Man this must be doing your head in now, what's the fuel pump like? And is the tank breathing okay? I'm seriously not looking forward to first starting mine now lol!
fuel pump seems fine and i seem to be gettin fuel as its overfueling lol, im trying to flash the codes my self but i dont have the mil warning lamp fitted, just the 2 pin diag plug comming from my loom under bonnet! iv tried this so far
and also tried putting positive part of LED in to plug and a switch comming off the earth to the earth terminal like the same way this works:
http://www.tooled-up.com/artwork/ProdPD ... 079ins.pdf
but all i get off both ways is the light staying on permanantly
anybody have any other tips or tried flashing there own codes? its wired in correctly before asked and iv double checked a million times
