Sim, ainda sou propietário. Mas não sou da Covilhã...fiesta18d wrote:Muito Boa tarde. reparei que a viatura tem Placa portuguesa, por isso deduzo que seja português, gostaria de saber se ainda é proprietário da viatura, e se por acaso não é da zona da Covilhã.
Obrigado
My 406 HDi Griffe
- atadinho
- 1.6 8v
Re: My 406 HDi Griffe
Helder - Nov 1983
Peugeot 406 2.0 HDi Griffe - 2001
Ex - Opel Frontera 3P 2.5 TDS Arizona - 1998 - Powered by VM Motori!
- atadinho
- 1.6 8v
That light comes on when oil pressure or oil level is too low. I've driven hundreds of cars and every single one had that light...dogslife wrote:Hadn't noticed before - but it's got an oil pressure warning light, (which ours don't have).
Helder - Nov 1983
- RayneR
i think almost or i would say all cars have that, can't remember seeing one without it ... even my ex clio from 94 had that ...
2000/May 406 Estate 2.0 HDI 110bhp DW10ATED now with 205k km & now with cruise control & now remaped @ 134bhp
Yes, virtually everything has them.....
except 406 HDi's. (at least UK spec ones anyway).
Really? Is this a multiplexed thing cause my 110 has one.dogslife wrote:Hadn't noticed before - but it's got an oil pressure warning light, (which ours don't have).
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Well, after a bit of looking at this forum, it appears that on a non multiplexed HDI the oil light comes on with the ignition, and not on a multiplexed one. Slightly wierd. How does one know it's workng? Just been looking at a multiplexed one and thought it was a fault!
Oh well, check on here first is the lesson.
- RayneR
busman, that doesn't make sense, why it doesn't turn on when ignition is turned on only on multiplexed ? That way you can't know if the sensor/light of dash is working ...
Exactly what i thought, but they all seem to do it. Check out other posts on this forum.RayneR wrote:busman, that doesn't make sense, why it doesn't turn on when ignition is turned on only on multiplexed ? That way you can't know if the sensor/light of dash is working ...
Edit. Just spoken to the pug stealer up the road, and he said, ''yep, they all do that, its a pug thing.''
