usually go for 16v cars that sit half way all day long so not used to it sittin low
Where does ur temp gauge sit??
podu
mine sits at 70 or just above in traffic, wnet as high as 80 in hot weather just wondering if thats normal really?!
if you dont do it, it wont get broke!!
- Blue406
- 406 Gimp
Re: Where does ur temp gauge sit??
Thats about right mate. My 2L sits between 70 and 80 most of the times. goes to 100 if I'm standing in traffic a long time.podu wrote:mine sits at 70 or just above in traffic, wnet as high as 80 in hot weather just wondering if thats normal really?!
- Captain Jack
- niz406
- Admin <BR>Turbo God
Well it used to stay @ 70 degrees and never go higher regardless of weather conditions..... BUT THEN..... I let some muppetts a a garage do an MOT for me, when the car came back it was @ 100 degrees and smelt of clutch and thrash ! !
2 new cooling fans, a thermostat, a new temp sensor, and a shed load of coolant and now it sits between 75 - 90, but never goes over 90.... fans cut in @ 87 degrees and take it back down to about 75 before shutting off....
GeordieBoy
Mine is fcked, its up and down like a prostitutes knickers.
Thats something else I need sorting. It used to be ok but the washer rubber pipe came off and when I went to clean the windscreen it went all over the coolant reservoir and electrics.
Vehicles I own:-
Vehicles I own:-
