hi everyone i was just wondering when i remove the electronic lucas pump will this cause any problems apart from the eml being on? and can i just use the old stop solonoid wire? i am just unsure if the ecu will cut the feed with the pump being dissconected thanks for any help
carl
2.1 pump removal
Re: 2.1 pump removal
if the batteries taken out during the procedure the car is none the wiser about parts being removed.
thanks again
carl
Read this
http://www.frenchcarforum.co.uk/forum/v ... hp?t=27900
but use the Lucas pump bracket (after swaping the studs over to the other holes) and you can still use the cambelt cover.
406 2.1TD GLX estate
Xantia 1.9TD VSX estate
brew my own biodiesel
excelent thanks for that can the rev counter be sorted by fitting a 96 ecu or is it not a straight swap?
thanks again
carl
thanks again
carl
I never got round to fitting one so I can't say for sure.
