lucas to bosch fuel pump change. anyone please??
omega
Re: lucas to bosch fuel pump change. anyone please??
Post by omega »
are you getting fuel to the injectores?
If the pump's from a 406, they, (at least the later ones), have some electronic gizmos and an ecu - though whether that's integral with the pump.or elsewhere, I don't know. (Someone else may be able to explain better).
The conversion you've done, or Bosch pump onto 2.1 TD, (which we all thought you meant), is fairly common, but most people use an older spec Bosch pump, from a 405, or early Xantia.
Do you know if the stop solenoid's working, have you got fuel at the injectors?
blake
Post by blake »
im not sure at all, ive just connected it up as it is. i'll check for fuel now. cheers
blake
Post by blake »
ive just loosened off the fuel lines and diesel came out under pressure, so i assume its getting to the injectors?
blake
Post by blake »
ive just been told that if ive got air in the fuel lines it wont run. is that my school boy error? :oops:
GeordieBoy
Post by GeordieBoy »
You'll need to move the pump up/down to get the timing right, its trial and error unfortuanately.
Vehicles I own:-
jamjar1383
Post by jamjar1383 »
are u sure the cam and crank timing are spot on???
d9 hdi 90 rapier estate
GeordieBoy
jamjar1383 wrote:are u sure the cam and crank timing are spot on???
If it is, and the IP is non ecu controlled, then loosening the bolts on pump and moving it up/down changes the timing.
You need to get it so engine starts, then slightly loosen bolts and move it and listen to get the right timing, engine noise should tell you when its right.
Vehicles I own:-
blake
Post by blake »
hi, ive tried turning it over with fuel lines not connected and there is no fuel coming out at all. do i need to look at the fuel solenoid then? im not sure what that does.
blake
Post by blake »
yeah i marked both cam/crank before removing belt
GeordieBoy
blake wrote:hi, ive tried turning it over with fuel lines not connected and there is no fuel coming out at all. do i need to look at the fuel solenoid then? im not sure what that does.
Immobiliser, you might have to put a live/ignition live 12v feed to the stop solenoid.
Vehicles I own:-
blake
Post by blake »
blake
Post by blake »
is the solenoid the one circled in blue or red? ive wired up the blue one and earthed it through the pump, but still no fuel. also the part ive circled in orange, does anything connect up to that? thanks
According to this http://www.vegetableoildiesel.co.uk/for ... p?tid=3233 it's the one in the blue circle. Looks like another useful thread to read (apart from the bit where he knackers his engine... )
blake
Post by blake »
steve_earwig wrote:According to this http://www.vegetableoildiesel.co.uk/for ... p?tid=3233 it's the one in the blue circle. Looks like another useful thread to read (apart from the bit where he knackers his engine... )
thanks very much, the thread looks very helpfull, back in the garage i go. cheers :D
