thinking about south west car meet any one intrested
Want to organise a (legal) cruise, meet up, or have news on one? Give us the heads up!
Re: thinking about south west car meet any one intrested
I gradually changed the entire lot apart from the water pump which was fairly new.
Main culprits were; radiator - like swiss cheese, top and bottom hoses, and the not so obvious; the thermostat seal which had perished away to virtually nothing.
I only found it after I'd changed all the other parts and had put in red antifreeze which left a nice tell tale stain under the thermostat housing! I changed the 'stat as well for good measure although I think the old one was perfectly fine to be honest.
dragonslayer
Post by dragonslayer »
cheers mate looks like i found my culprit mines leaking from there a bit where can i get a new seal.also which way round is the thermostat go in as min isnt there.it hasnt got one
cheers mate
dave
You can get the seal from any motor factors or a dealers, they only cost £2 or so.
From memory the 'stat can only fit in one way, so you'll be ok there :)
ARGH!!! I saw that top picture and it was like insta-flashback to a nightmare!
Took me over an hour in the freezing cold to get the old 'stat out of my tubby because the seal needed chiselling out...
I must have been very lucky Matt; mine just popped straight out!
swiss
Post by swiss »
Make it during the Easter holibobs and I'll make the effort to attend. Assuming I can get permission from the higher-ups, of course. By which I mean my wife.
We can have a 'noisiest 406' tourney, so I can bet on myself and make a stack of money :)
The man with no car
Creedy
Post by Creedy »
your problem (loseing water but not leaking along with high temps) could be head gasket? any white smoke from exhaust?
dragonslayer
Creedy wrote:your problem (loseing water but not leaking along with high temps) could be head gasket? any white smoke from exhaust?
no white smoke and it doesnt over heat.the head gasket was replaced two years ago i got reciepts for.i think it is leaking but cant find the leak yet.i think it might be from a blead nipple some where
dave
