Wanted, steering rack pipe
D9406
2.2 16v
Post by D9406 »
Wanted, the metal pipe from the steering box that returns to the power steering resevoir. 406 HDi 99 plate.
Andy
Re: Wanted, steering rack pipe
Someone might have something but I think you'll be very lucky if they do.
Might be an idea to speak to a hydraulic hose company to make up a flexi repair piece or something?
dirtydirtydiesel
Post by dirtydirtydiesel »
D9406 wrote: Tue Oct 20, 2020 11:00 am Wanted, the metal pipe from the steering box that returns to the power steering resevoir. 406 HDi 99 plate.
Andy
Definitely worth joining the farcebook group for this,
There's plenty being broken on there & a couple of people who are actually car dismantlers & post stuff
Payment via PayPal, so covered if stuffs wrong or not as described.
I'm not a fan of Farcebook, but I do use it solely for spares and guidance regarding my cars.....
There is a dedicated 406 spares page.
I'm not a fan of Farcebook, but I use it solely for spares and guidance for my cars.
There are a couple of 406 pages, along with a group for 406 spares.
D9406
2.2 16v
Post by D9406 »
Found one, still on car at moment breaker wants £35 just for the small pipe from rack to first flexi pipe.
Still, rest of car is good so I'll probably have it to keep the old girl going.
PeterN
Post by PeterN »
There is probably one on my scrap car - but I'm in Dorset.
D9406
2.2 16v
Post by D9406 »
Thanks Peter,
A replacement part has been sourced after a lot of searching. Amazed at how difficult it was to get one but I wasn't going to scrap a car off for the sake of a bit of aluminium pipe.
Tip, check the heat shield by the steering rack for security, mine had worked loose and sawed through the pipe, it's now been removed.
Andy
D9406
2.2 16v
Post by D9406 »
Hi Peter,
Do you mind if I pop down to see if your scrapper has the part I need please?
I see from your profile that your licenced,
Best 73
Andy
M0RON
