Doggy wrote:Nice to hear from you again Stu. Don't be a stranger.
You may have noticed we now have the Volvo corner, a few other Peugeots, the occasional Ford owner, so no reason you can't join in.
Thanks Eric. Don't really visit any forums at all anymore as things have been really busy over past couple of years. A wedding, several (expensive) trips to Ireland, 1 Grand-daughter/God-daughter & a lot of work (been working on agency on my days off) hasn't left a massive amount of time for much else. You wouldn't recognise the car anymore - it's minging by my standards as it hasn't had a proper clean since last March!
benczuk wrote:Indeed, what are you running at the minute Stu?
Still got the Zafira. It's managed to hit 71k miles now! Did briefly look to get rid & pick up an older, cheaper (but still low mileage) Beemer or Merc a while back, but opted against it as the Zafira will probably be worth more to me in the long run as it will still be low mileage when I do eventually change, but the older it gets, the rarer mine will end up being.
GingerMagic wrote:Hi Stu, long time no see ( Pugfest 2013....? ) Hope all is well?
I would be interested in a set of the bolts for steelies to go on the wife's Picasso, as her alloys have long gone and steelies are the way forward, and sideways into kerbs
and I still have the alloy bolts but with steel wheels which I want to sort out and get rid of the lockers at the same time.
Cheers, Kelv.
Yours if you want them Kelv. Seeing as the weight of them will make them a bit expensive to post, are you venturing up past Andover at any point?
