Wanted 2001 406 estate aerial
climbersuk
Post by climbersuk »
Hi,
My Aerial isnt up to much, and needs replacing, however it is rusted to the base unit on the roof, so I basicaly need the whole thing. Anyone got one spare? Been scrap yards and the only 406's that they have all have the aerials at the front of the roof, but mine is at the back.
Cheers
Stu
2001, 2 litre, 90hp (looking at upping that) 406 estate
gumby6371
Re: Wanted 2001 406 estate aerial
Post by gumby6371 »
You should be able to get something very similar to the original from your LMF for about a fiver.
Take the old one out and take it with you, not worth fitting second hand ones. I wouldn't think the dealer price would be that bad but you never know.
Be careful removing the light fitting to gain access as they can go brittle over time and snap when you lever them out.
trem1
Post by trem1 »
is your ariel at the front of the roof or the rear ??
rear is £48 from Stealers
front is £6.65
bet i can guess which one yours is :(
You don't need to guess
climbersuk wrote:mine is at the back
:P
Oh, the ariel moved to the back of the roof when they went multiplex :shock:
Yowzer! - the 48 quid is just the base :evil:
Hold on.... 6561 GP
2 document(s) found for 307 RESTYLING
2 document(s) found for 206
1 document(s) found for 607
1 document(s) found for 406 (RESTYLING)
1 document(s) found for 1007
4 document(s) found for 307
4 document(s) found for 306 (RESTYLING)
1 document(s) found for 607 RESTYLING
1 document(s) found for 807
1 document(s) found for C4
1 document(s) found for C2
2 document(s) found for XSARA II
1 document(s) found for C8
1 document(s) found for C5
1 document(s) found for C3
1 document(s) found for XSARA
climbersuk
I think I shall now not be bothered about listening to the radio then............. 48 quid!??!?!?!?!?!??!?!!??!?!?!
Have it orf, soak it in WD, give it a twist.
Then replace with coat hanger.
steve_earwig wrote:Have it orf, soak it in WD, give it a twist.
Advice or just kinky fantasy? :shock: :lol:
I guess I'm aiming to end up as someone's sig :roll:
Hi, I'm stripping my 406 Estate in the next couple of weeks - it has a rear mounted base unit, but no aerial.. :wink:
Any takers?
Kelv.
does this look about right?
http://www.ebay.co.uk/itm/300682428631
climbersuk
mjb wrote:does this look about right?
I shall have to take mine off, but on 1st inspection it looks very similar. Shall try and look tomorrow, if I can figure out how to get the headlining down enough.
climbersuk
GingerMagic wrote:Hi, I'm stripping my 406 Estate in the next couple of weeks - it has a rear mounted base unit, but no aerial.. :wink:
Any takers?
Kelv.
I am an idiot, only just seen this message, although I saw messages after that. How much would you be looking for it?
Hi, maybe £5 plus postage. I will see how hard it is to remove before promising it, will have to remove headlining - maybe at the weekend?
