Some D8 1.9TD Bits For Sale
ally406
Post by ally406 »
Genuine Peugeot/Citroen Outer CV joint kit. Part number 3293.03. It's missing the small circlip, but you can re-use the one you have (pattern parts don't even come with one). Comes with everything else, 2x boot clips and sachet of grease. Dealer price £22.19, £12 delivered.
Genuine Peugeot/Citroen Inner CV joint kit. Part number 3287.81. It's missing both CV boot clips (I usually uprate to stainless ones anyway). Dealer price £18.80, £10 delivered.
Rear wheel bearing kit, Continental branded pattern part. This was purchased for a D8 1.9TD without ABS. £20 delivered.
Clutch fork bushes. Genuine Peugeot, part number 2175.21. £2 each delivered. Unfortunately these are minimum quantity order of 5 at the dealer so I have 4 left! A must have item if you are changing the clutch.
Genuine Peugeot/Citroen crank shaft oil seal, part number 0127.28. I couldn't find these in time for the picture. I have 2 of these, dealer price £18.47 each. £10 delivered.
