406 exec HDI estate, ready for scrap, salvage read on...
Re: 406 exec HDI estate, ready for scrap, salvage read on...
That's a shame still interested.in. Paint code mate
And a few other parts but as I will be driving across to get parts it all hangs on.paint code for.me
Ok, im guessing pannels if its paint related? Fyi boot, passenger door, bonnet (from memory) are all no good.
406 '01 110 GTX estate in white, the new tow car.
Lol I'm after drivers door wings we shall see
That's the one.Floodys wrote:
Quinny, passenger wing moulding? Do you mean the small bit of rubber/plastic strip? Ive a feeling its gone but will check.
1999 V 406 HDi sold in 2011
2002 02 plate 406 HDi 110 bought 16/11/2013
Cheers yeah the lcd strip bit above the climate control unit, if its not pixelated or scratched. Yeah the plastic parts and the chrome twisty part, if you have two of those i'll take them both of you as i'm not sure if the one thats actually still on mine works!Floodys wrote:Ill get all the bits off car tomorrow and post up here when im home, i dont want much for stuff, just happy that it dont get crushed!
Time display unit? The big lcd bit above radio? And retain ring? Piece in boot floor that the chrome twisty bit screws too?
Cheers
MAtt
2000 2.0 HDI Estate GTX 90 bhp
Got car today, broke it up a bit.
I have the following
Lcd display but no idea on condition, pixels etc.
2 x sets of lock ring things that you asked for matt.
No trim on wing as got knocked off in accident.
Not sure on paint code but i have a pic of vin plate and i think code is on there? Let me know how to identify it Dave?
Odd btis i have taken off if anyone interestd?
Fuel pump
Light sensitive rear view interior mirror
Fuel lock set and bsi, ecu
Drivers side electric wing mirror
Tape player radio
Headlights
O/s front fog/driving light
Fuel pump
Tape player radio
Headlights
I can get it from the sticker on the drivers side when you poen the door. Will have tyre pressures on it
I thought i read somewhere its also on the vin plate, send me your paint code and i will see if it is same as any info on the vin plate.
Hi mate - look for the sticker on the A piller inside the drivers door. At the bottom of the sticker there should be 4 letters in capital followed by **.
This is the paint code.
Did you remove the ignition barrel and transponder to go with the ECU and BSI? I sold mine on ebay for over £100 for the lot..
Funny enough ginger as i broke up car i checked on the bay and someone had a set on there and it sold for about £35 so i took it all off car!
Out of interest would you know if i need to sell bsi and the what looks like a ECU with it to make it work together? If not ill just sell the locks and barrel and transponder as a set!
If i could get £100 ish for it then great!
I sold the BSI, ECU ( you need both together to be compatible ) door locks, ignition barrel, transponder, keys with PIN code and also the speedo clocks.
BSI, ECU and clocks all hold info about the cars mileage, so ideally need to be a set to guarantee they correspond.
I got you! Think ill whip out the clocks too then to add a bit extra cash! They would only get crushed! Cheers mate
I had the misfortune of overlooking the clocks on my last 406 when i installed cruise control from a different model and it added the mileage from the new ecu/bsi to the clocks, it more than doubled my mileage in one foul swoop....i didnt know i needed the clocks at the time and had to put it through an MOT with the new mileage on it, but everything still worked fine just the mileage was crazyGingerMagic wrote:I sold the BSI, ECU ( you need both together to be compatible ) door locks, ignition barrel, transponder, keys with PIN code and also the speedo clocks.
