Breaking - 52 Plate Exec. Est 110 HDI
stealthe
Re: Breaking - 52 Plate Exec. Est 110 HDI
Post by stealthe »
no2lurch wrote:non smoker kit?
Sorry, no.
stealthe
MFACTOR001
Post by MFACTOR001 »
HI I AM AFTER THE BOTTOM INTERCOOLER PIPE ?.
pfusi1
Post by pfusi1 »
I'm after a few (tarty) things:
1. O/s Rubber Door Strip
2. Front drivers door rubber strip surround.
3. Front downwards section of o/s front mudguard. (mudguard is in three sections, I need the middle section that runs down the front of the wheel arch and attaches to the small triangle section at the front).
4. Flat rubber/plastic strip on inside rear of o/s rear door.
5. And possibly the handle that attaches to the inner sunroof panel.
Cheers, Phil
stealthe
Post by stealthe »
pfusi1 wrote:I'm after a few (tarty) things:
Cheers, Phil
I have all of those parts, I will need to id them in the big pile of stuff that's in the garage, got any pics?
stealthe
Stealthe - do you still have the COM2000 stalk? Mine's on its way out soon.
stealthe
Post by stealthe »
Captain Jack wrote:Stealthe - do you still have the COM2000 stalk? Mine's on its way out soon.
I have, but I would have to mention that the action of the indicator stalk is definitely 'looser' than the wiper stalk.
stealthe
no2lurch
Post by no2lurch »
Rear elctric window isolator switch?
Current car - Ph3 1.8 306
stealthe
Post by stealthe »
no2lurch wrote:Rear elctric window isolator switch?
Do you mean the drivers window/mirror switches?
stealthe
no2lurch
Post by no2lurch »
stealthe
yeah, although the only switch on my cluster that doesn't work is the isolator!
bobdylan55
Post by bobdylan55 »
how much for just the cd changer? presuming it is a pu-2293a clarion?
stealthe
Post by stealthe »
bobdylan55 wrote:how much for just the cd changer? presuming it is a pu-2293a clarion?
It's a clarion pu-2293d. It's got a blue 12pin connection on the back.
stealthe
bobdylan55
think they work aswell. How much for just the changer? as ive already got jbl headunit and amp etc. cheers
no2lurch wrote:although the only switch on my cluster that doesn't work is the isolator!
Lurchy, the switch sticks over time - you need to give it a good old workout loads of times on/off and it should free up and start working again (they never get used enough).
Stuff half a tin of switch cleaner through it and give it a few hundred presses...
Know I'm resurrecting a bit of an old one here, but you say that most of the parts wouldn't fit your GTX due to the wiring changes? I got told a while ago that any D9 seats would fit any other D9 (of the same body of course), but it would appear from what's been said here that the seats from a multiplex model (the 52 plate) are actually NOT compatible with an earlier one.
Is this the leather interior that somebody mentioned in my other topic the other day?
viewtopic.php?f=28&t=12318#p109404
