Wanted!! 406 lowering springs
Wherry008
Post by Wherry008 »
Hi guys I am looking for some second hand peugeot 406 saloon lowering springs
Re: Wanted!! 406 lowering springs
Hi mate - try on the coupe club - www.406coupeclub.org - as the coupe and the saloon share the same set up, the estates are different.
Hope this helps you find some.
niz406
Admin <BR>Turbo God
Post by niz406 »
I have a custom set of rears available.... but you will need shorter dampers.
They are 65-70mm drop at the rear I believe, which level out a standard 40mm drop at the front :)
Never fitted, custom built by Sheffield spring steel.
Niz406
