Things to do
- Captain Jack
Things to do
So, after my nightmare with the bottom mount, I still have the following things to replace/repair:
1) Master clutch cylinder - already have it, just need to get off my arse to do it. Space seems limited, so hope it doesn't turn into another "bottom mount"
2) Flexi-hose pipe / Cat - grr... costs more than I can currently afford, but will need to do it as it smells in the car if I am not moving. Will get rid of the low rev grumbling noise too
3) Glow plug relay - works, but one wire is loose. More expense.
4) A damn good scrub!
Re: Things to do
1). Clean / replace / remove continually troublesome DPF.
2). Trace / resolve exhaust leak, (probable flexi-hose pipe).
3). Replace swirl chamber actuator.
4). Remove last reamining locking wheel bolt I've lost the key to.
5). Replace failed LED number plate lamp & both lamp assemblies.
6). MOT Jan, Tax Feb.
7). Clean it for the first time since September
Swap
Swap
Re: Things to do
S'funny (no it's not really) but through 3 years of no-one mentioning these things the FIRST thing I'd say to anyone now with a HDi is "check the bottom mount and the eggsauce flexi" - seems to be a bit of a theme now.
- puggy
- Resident Pervert
Re: Things to do
Replace front fogs (they work but full of condensation )
bottom engine mount
2 front tyres
bottom engine mount
2 front tyres
Re: Things to do
1. Drive it until it goes bang.
2. Walk.
2. Walk.
- highlander
- PowerFlow Shill
Re: Things to do
Need to do (restoration):
1) Sort out the exhaust leak
2) Sort out the passenger-side electric window (doesn't work; drivers' one does)
3) Replace the exterior temperature sensor
4) Get the scratches removed from the front bumper (scraped it off a rock in the dark)
5) Replace the rubber stoppers on the boot lid (boot lid bangs off the rear bumper)
Want to do (improvement):
1) Leather interior (seats, door cards, steering wheel)
2) Tighter suspension
3) Stainless steel exhaust
4) Induction kit (not just a cone filter, but something with a good cold air feed)
5) Stalk & MFD adapter for my Sony stereo
- Officer of the law!
Re: Things to do
For me on the 407...
1) Fit induction kit. i've had it several months and not yet bothered.
2) Fit uber rare SP pedals. Ditto.
For the FZR600 3HE7...
1) Everything. I'm mid way through a full rebuild. Have a peek http://fzronline.com/forum/viewtopic.php?f=21&t=4494
For the 99 R6...
1) New tyres.
2) New sprockets and chain.
3) New front seat.
Then buy an 86-88 FZ600 so I have a full set of Yam middleweights.
Then a shed so I can clear the garage and get an FZR400, 750 and 1000 so I have a full set of Fizzers as well.
These darstardly plans will doubtless take a few years to reach fruition
For the 99 R6...
1) New tyres.
3) New front seat.
- DaiRees
- Site Admin
Re: Things to do
1, Rear brakes (done today)
2, 2 new tyres (done today)
3, MOT (before 8th Jan)
4, 8yr / 80K service (including cam belt) - (TBA sometime in January)
Re: Things to do
Looks the same sort of state my TDM's in just now (and will be until I have some cash to order some more parts). At least bikes don't take up so much roomturbolag wrote:Then buy an 86-88 FZ600 so I have a full set of Yam middleweights.
Oh look, you is a radio ham
Re: Things to do
Yeah, passed my Ham foundation licence earlier this year.
Re: Things to do
Foundation? Used to be C&G RAE. I guess it's all changed since I did it about 25 years ago
Re: Things to do
Clutch?????puggy wrote:Replace front fogs (they work but full of condensation )
bottom engine mount
2 front tyres
- 2.2 16v
Re: Things to do
My things to do list comprise of
1. replace exhaust downspout/flexi/cat - just waiting for the xmas faries to drop one under the tree for me
2. knowing my luck, i'll end up replacing the middle and back sections of the exhaust as well
3. replace drivers side fog light bulb - missing in action
4. get the a/c regassed
5. find a set of D9 GLX/Rapier alloys
6. Give it another good bufty session in the spring
(all of the above are subject to change as the cars discretion, ie as and when IT decides something else needs doing first!!)
2001 D9 406 Hdi 90bhp Rapier Estate - Platinum Silver
1999 306 GTi-6 Weekend Toy- Astor Grey
- Bailes1992
Re: Things to do
This is my list of stuff to do in order of priority...
General Wear and Tear Replacments...
1) Indicator Stalk
2) Engine Mounts
3) Bushes (Possibly get oem shocks and eibach springs while Im at it)
4) Service
5) Timing Belt
6) Breaks, there fine but I want to get new calipers, possibly braided hoses, Freddero DC2500 Pads and OEM discs.
Modifications...
7) Stereo
New Interior
9) Get my alloys refurbed and tyres.
10) De-Cat and straight through with a back box and get a stage one tune at the same time.
And prey it dosen't break again
1) Indicator Stalk
2) Engine Mounts
4) Service
5) Timing Belt
Modifications...
7) Stereo
- puggy
- Resident Pervert
Re: Things to do
OOooooooo !! you just had to remind me didn't youdogslife wrote:Clutch?????puggy wrote:Replace front fogs (they work but full of condensation )
bottom engine mount
2 front tyres
