V6 Minor/cheap performance upgrades?
MilesS835
Post by MilesS835 »
Hi,
After regretting selling my old manual V6 estate, I recently won a green V6 auto estate (D8) on eBay for £700 - MoT until December. It’s turned out quite nice after a bit of a clean! :cheesy:
Anyway.. the auto is a little bit slower than the manual, but not by a huge amount. I’d still like to make it a little faster though!
I’ve removed the little aluminium piece in the air box which I’ve heard can come loose at full throttle and jam in the butterfly valve! It actually had a bend in it which will have restricted air flow slightly. I’ve also disconnected the intake tube from the bottom of the air box which has not only made it sound a bit nicer under acceleration but I think it has made it a little more responsive and maybe a tad faster too!
Anyone else noticed an improvement from removing the pipe?
I’m now wondering if a cone filter type induction kit would make noticeable improvement?
Any other budget mods aside from a good service that can be done?
Cheers!
1998 Diablo red 406 V6 manual estate - Sold
1998 Dark green? 406 V6 auto estate
1981 DeLorean
1966 Reliant Scimitar coupe (in bits)
Re: V6 Minor/cheap performance upgrades?
Not aware of any mods of the kind you're looking for. Personally I would steer clear of any modified filter that results in you drawing in hot air from under the bonnet as opposed to cool air from the wheelarch at that's more likely to slow it down, though it might 'sound' faster.
Might be worth checking the coupe forum as there are lots more V6 owners on there: http://406coupeclub.org/
