Does anyone have SEDRE running in Windows 10?
and does anyone have a keygen that works? 'Cos that's as far as I've got, my XP machine died a few months back, both Windows 10 machines have Java installed but neither does anything useful. It displays but doesn't generate a key :(
Yep, the lack of access to Service Box is really starting to annoy me :evil:
trem1
Re: Does anyone have SEDRE running in Windows 10?
Post by trem1 »
Theres this verson of servicebox until you get it sorted,not as good but better than nowt
https://catalogs.ssg.asia/peugeot/?lang ... vzxPtKL8cU#
It looks pretty useful to me, thanks! :cheesy:
trem1 wrote: Thu Mar 11, 2021 3:54 pm Theres this verson of servicebox until you get it sorted,not as good but better than nowt
MUCH better than nowt, unless you've got a Citroen. :(
I don't suppose.......
trem1
Post by trem1 »
bet theres a citroen version out there somewhere
WillNZ
Post by WillNZ »
I have it running in w10 but within Vmware 12. Works fine but vin lookup no longer works, you have to manually select your specific model.
Serial 406hdi licker :cheesy:
I have seen that it needs some sort of container (Windows Xp or 7 I guess) but it looks like they've scrapped that. I have actually seen people saying they have it running on Win10, so I'd like to try that first. Unfortunately I'm still stuck at the first hurdle, I can't get the keygen to work, java 64 it opens but generates nothing, java 32 it just closes when I try to do anything :(
WillNZ
Post by WillNZ »
Yes, mine runs in windows 7 in vmware.
Problem I am having is getting the wiring diagrams addon to display. Program runs fine but no pictures... :frown:
I had a similar problem when I was trying to run the Citroen off of disk images, even if I remembered to load them I got an error.
I have found 1 problem with the keygen, it turns out Java didn't have enough permissions, so I gave it everything and now the 32 bit doesn't crash all the time. It still doesn't generate a key of course :roll: Somewhere I have my bro's old XP laptop, it's depressingly free of things like memory, disk space and processing power but I wonder if it has java on it.
batrst
Post by batrst »
i have windows 10 pro code and windows 10 usb bootable if needed
