Engine change
Engine change
Hi,I wonder if anyone could help,is it possible to put a 406 tdi engine into an older Peugeot Partner diesel van?Happen to have a spare 406 engine and a friend's van engine is knackered.
Re: Engine change
I'm not really up with swapping engines but.. Is it possible? Well, you could fit a jet engine in there, that's possible Is it easy though, that's another question.
It might help to know some details, 406 TDi what? 2.1 or 1.9? What was in the Berlingo? Earlier Berlingos were fitted with the XUD9, which would make things quite easy...
Re: Engine change
What year is your car, and what year is the van?
If they are both made after 1999 then it's more than likely they will fit, although you may need to swap injectors etc if the fuel system is different...
Re: Engine change
Hi thank you for replies.The 406 is 1999 1.9 diesel.The van is 2005 and a 2 litre.
Re: Engine change
Definitely a 1.9 diesel on the 406?
It's a changeover year so could be the earlier 1.9xud or the later 2.0hdi.
Re: Engine change
I'm confused, you have a 1999 1.9 XUD in a 406 but also have a spare 406 'tdi' engine - to possibly transplant into an 'older' 2005 van
Whichever way around this is you're likely to run into issues with immobilisers/ECU's/Keys/Wiring Looms etc in my mind.
I'd say that unless you have a spare engine of the same type (so you can rob all the ancillaries off it) then you'll be creating work for yourself here.
Scrap prices are supposed to be high(er) right now - your Van mate might be better weighing-in and buying another similar working van for cheaps?
Re: Engine change
Thank you all for replies not a goer then.
