Thanks for this -- I presumed they used a electronically-controlled throttle so it's good to hear they use a mechanical linkage which I'm more comfortable with. I'll add it to the list of jobs for this weekend (when I have daylight!) and will see if there is any slack.Doggy wrote: ↑Wed Jan 08, 2020 1:47 pm As regards the lack of oomph, it's probably worth checking the throttle cable for excess slack at the throttle position sensor, (near the brake servo).
With diagnostic kit you can accurately tell if you're getting 0 - 99%, but even without you can usually remove almost all of the slack by adjusting the spring clip on the outer cable sheath.
New 406 Owner
