807 OBD Pinout
OllieNZ
807 OBD Pinout
Post by OllieNZ »
Hi All,
Any chance anyone can pull up a wiring diagram with the cable idents for a 2005 807? It would seem mine has been messed with and I cant get my PP2K to talk to it
Regards
Ollie
frog
Re: 807 OBD Pinout
Post by frog »
If you give me the VIN number (PM me if you like your privacy) I can look it up on the SEDRE discs.
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 690.000 kms :cheesy:
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
OllieNZ
Re: 807 OBD Pinout
Post by OllieNZ »
frog wrote: Mon Sep 16, 2019 7:16 am If you give me the VIN number (PM me if you like your privacy) I can look it up on the SEDRE discs.
You've got a PM, thanks a million. Trying to get my pp2k to talk to this 807 has been a huge headache :evil:
Re: 807 OBD Pinout
Have you tried to use lexia, and tell it that the car is actually a Citroen instead..??
Worth a go if you have lexia installed too.
frog
Re: 807 OBD Pinout
Post by frog »
OllieNZ wrote: Mon Sep 16, 2019 7:09 pmYou've got a PM, thanks a million. Trying to get my pp2k to talk to this 807 has been a huge headache :evil:
I attached the schematic i think you are looking for: "diagnostic socket".
When clicked, Sedre asked me:
Select the vehicle configuration:
* discharge bulb
* absence of this/these variant(s)
I clicked on "discharge bulb" (i think it means "halogen headlamp bulbs" which i could see are present in Service Box).
Hope this helps. If you need any other schematic just let me know.
[The extension pdf has been deactivated and can no longer be displayed.]
Current "fleet":
Previously owned:
frog
Re: 807 OBD Pinout
Post by frog »
Here is an overview of items that may be of interest:
Note that each item is a high-level diagram that is in itself clickable. Details of specific electrical parts will appear only if one clicks further, into the boxes shown in the high-level diagram. So it is a bit of a PITA :(
Current "fleet":
Previously owned:
OllieNZ
Re: 807 OBD Pinout
Post by OllieNZ »
frog wrote: Tue Sep 17, 2019 10:02 am
* discharge bulb
That really helps, I don't have discharge lamps and looking at that mine is definitely wrong according to that.
Could you please also give me the "diagnostic connector" schematic too.
Regards
Ollie
frog
Re: 807 OBD Pinout
Post by frog »
If you PM me your e-mail address I can send you a larger (zip) file with a number of diagrams. Attachments on this forum are limited in size to 256 KB.
Current "fleet":
Previously owned:
