Hi all,
not been on for a while, still got the 406 hdi gtx 110 estate. 140k.
put it in for it's mot, failed on handbrake so the tester took it up the road to drive it with the handbrake on, back on the tester and it passed the handbrake test easily. Next fail item was a rear seatbelt wouldn't latch, a poke around inside with a screwdriver and something clicked, seat belt then locked.
So another 12 month ticket on the old girl, 1999 vintage.
Andy
Mot again
- 2.2 16v
Mot again
Re: Mot again
Excellent.
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
Re: Mot again
I always used to drive to the MOT test and give the handbrake a good workout on the way there, even working it sharply at over 40mph to clean up the braking surfaces as they get glazed over on the 'in the drum' type set ups.
That's impressive for a 20 year old car, you forget how old they are sometimes. It was always reported on here in peak times how easy going the 406 was with MOT's with little to no corrosion or suspension issues.
My handbrake on my saloon was always quite good for some reason.
