Tearing my hair out - Galletto 1260
Sagwala
Post by Sagwala »
Aaaaaggggghhhhh :oops:
Can't get the bloody thing to do anything, Please help me.
is it because I am using Windows 7. Would be grateful if someone would hold my hand through the process
regards,
Trevor :cry:
Re: Tearing my hair out - Galletto 1260
Sagwala wrote:Is it because I am using Windows 7. Would be grateful if someone would hold my hand through the process
regards,
Trevor :cry:
Don't know for certain, but I suspect so. Galletto is almost certainly an old DOS program, so will work with Windows versions up to and including XP. I suspect there's some sort of 'virtual machine' utility you can use but have no personal experience, sorry.
For XP and the like, simply copy everything off the CD to a new folder and create a desktop shortcut to point to the only .exe file
I keep an ancient XP laptop just for Galletto & PP2k
gumby6371
Post by gumby6371 »
I use VMware on my windows 7 laptop, they do a free for home use version and there is a good tutorial on there website for the install.
Best of luck
Sagwala
Post by Sagwala »
Is there anyone in the Midlands area who would be willing to flash the software for me?
Depends on what you call the Midlands - I'm in the East Midlands (NN17) and could do it for you.
Sagwala
Post by Sagwala »
Hi, I,m in Nuneaton nr Hinckley, so if you're Corby, then only a short trip down the A5 for me?
About an hour, I'd say.
PM me to make arrangements if interested.
Sagwala
Post by Sagwala »
Morning, Thanks for that, really appreciated. I spoke to HDi tuning yesterday and they explained that the Galletto 1260 was very problematic and that a MPPS FLASH CABLE was a much better option.
So I have bought one to try. I will give that a whirl when it arrives and if no joy then I will 'Corby bound' and will make the necessary arrangements with you.
Will keep you posted on my progress, cheers. :P
Hi Trevor, I never really trusted my Galletto as it was always freezing/crashing etc..
Where did you get the MPPS FLASH CABLE from?
Kelv.
Sagwala
Post by Sagwala »
Hi Kelv,
haven't received it yet but ordered it from EBay.
I re-installed my Galletto yesterday, on my old PP2000/ diagnostics XP laptop. I'll try to flash my ECU with a different map ( 200 down to the 180 ) as a practice run for the proper remap, when its all sorted.
