Hi there guys!
Where would I find a pair of misting washer jets? The double jetted ones I current use (and have replaced before) frankly are cr*p, and have seen a lot of people suggesting to you the misting variety fitted on later cars - trouble is, I cant find them anywhere!
Any ideas?
Many thanks!
Benjamin
Misting washer jets - where to get them?
150hp/330nm • Powerflow stainless exhaust • Kevlar clutch • Cat delete • EGR & Doser delete • Leather interior • Windows tinted • Cruise control • 5 dial cluster • Yatour bluetooth • Starfish alloys • Twin rear fogs
Re: Misting washer jets - where to get them?
The misting ones that are used on the Coupe are different from the ones on the Estate / Saloon. My later model 406 Estate has misting jets already - I assume it is standard on later models.
Mine are part number 6438 HO, according to service box.
They're standard on D9s after RPO 08729. I put some on my D8 but I found the jets sprayed too low down the screen to be much use and... they're not adjustable.
