On the way I've managed to scrounge some free things.
First was a Numatic Edward hoover that stopped working, it's basically a Henry on wheels. I was told it had been making a screeching for a while and eventually died.
Stripped it down and found that not only had the brushes on the motor failed but the springs behind them had actually worn away too!
Picked up two brushes for £8 each, swapped them over and now it works a treat! Cleaned it thoroughly and even disinfected it.
A £200 hoover for £16
My Parents recently sold a static caravan they've had down the Gower for 12 years. Unfortunately as Me and my Sister have gotten older we have used it less and less till it wasen't worth keeping any more.
I managed to scrounge a flymo that has only been used about 10 times, a petrol strimmer which was bought in the mid 90's and a Kartcher pressure washer. None of which have been used in about 5-6 years!
The Flymo was great and cut our front lawn without issue! I gave it a quick clean, sharpened the blade and boxed it all back up ready to move out.
The strimmer had a few issues. First the engine was a bit stiff to turn. I removed a cover on the side of the crank and used a syringe and my finger to put a thin layer of two stroke oil on the bore and around the crank while turning the engine over very slowly (I had the spark plug removed so there was no compression). Once it started easing up I put some fuel in it, cleaned and gapped the spark plug and tried to fire it up. After about 15 mins of cranking it wouldn't fire! I looked closley and noticed the fuel hoses had all perished and were leaking all over the place. I managed to get two new fuel hoses and a spark plug for £6, fitted them and it fired up right away, although a bit smokey at first.
I have a stream running through the back of my garden. Behind it is usually 2 foot high of grass and brambles and the odd snake.
Unfortunately I wasn't so lucky with the pressure washer. I connected it to a hose pipe and noticed it was leaking from the head seal. I managed to get one from Karcher for £3 delivered. I also bought an 'O' ring kit from Halfords and replaced all the 'O' rings that I had removed when doing the job.
I hooked it back up again, bled all the air out the system and gave it some power. It fired straight up and was working beautifully for about 30 seconds. The pressure washer slowed and slowed until it stopped altogether.
I stripped it all down and a bearing on the motor had seized up causing the motor to overload and burn out.
Ahh well, win some you loose some!
