Window wipers
Window wipers
Having an issue with my winscreen wipers, no matter what setting I put them on, even off, they run for 30secs then stop, I turned off all other power ie stereo, heated windsceen etc and they worked fine again, anyone know what the problem could be???? If not I will see you all at the haynes motor museum, if its raining I will be the one driving with my head out the window so I can see where I'm going.
Re: Window wipers
I would suggest a BSI reset first, then see what happens from there.
viewtopic.php?f=10&t=10968&p=97438&hili ... set#p97438
Please stick to the info, if you disconnect the battery too soon after the ignition has been on you could affect the immobiliser / key and car may not start.
Re: Window wipers
Does it only do this when there's other stuff running
As youve mentioned above heated screen etc.
If so I'd have the multi-meter out and be checking what voltage the alternator is giving out..
These cars with Bsi's are twitchy so if there's a drop/drain in volts it can shut things down
To keep the main things going.
As above mentioned, the bsi reset is worth a try.
Re: Window wipers
Ok ty I will try both when it stops raining . I had it all turned off on the way to work and still didn't work fit my wife went out later and it was ok
