Bought another 406
Bought another 406
I got myself a cheap 2000 HDi 90 with 160k miles for £230
Its had a right old thump on the back quarterpanel, the boot does not close
It starts and drives, although its an MOT failure because of rotten sills, but it should do as another good breaker car, the alloys are the best part of the deal:
They are 16's :cheesy: it shouldnt take an awful lot to refurb them into acceptable condition.
Re: Bought another 406
Got yourself a bargain there, the whole car looks like it will clean up quite nice, apart from the rear quarter..!
Are you keeping it or breaking it?
Ares
Post by Ares »
i belive he is breaking it since he told there are rotten sills which are MOT fail but car does looks like its in good condition i would save it
Yep i bought it for breaking (spare parts and some YT videos),
it failed the mot for rust, the sills are shot, and the rear boot floor is rusted. However it drives ok, the crankshaft pulley is making its noise,
its my first time driving a 90 and its not too slow, ok it would never overtake much, but it is acceptable.
The alloys are off and in the boot of my own car, im going to get them refurbished and replace the MVK alloys i have on at the moment
Some questions about this car
behind the glovebox lid there is a plastic door/opening which is not present on my car, what is it for
what is the red square switch like thing mounted to the suspension tower on the passenger side?
FarmerPug wrote:Some questions about this car.....
Fuel pump cut-off switch?
Why all the rust? Was the car in a prang at some point in its life and poorly repaired?
Never heard of a boot floor in a 406 rusting out before - afterall, it's not a LR Discovery :P
markw
Post by markw »
FarmerPug wrote:behind the glovebox lid there is a plastic door/opening which is not present on my car, what is it for
Do you mean behind as in 'inside' or 'on top' of the dash area? If on top, that's where the passenger air bag lives on D8's.
If inside...I dunno! :oops:
'Tis certainly a D9 in the pics [/406 Geek] :oops:
The opening is found when you actually remove the glovebox lid completely, ie the 2 pins and drop the lid, behind it there is a wee flap held closed with a screw it comes off but i dont see any reason for this panel. The glovebox on this car is also a bit trickier to remove than mine, the screw in behind the glovebox lid that is supposed to go into a metal bracket has its head orientated so you need to get at it from the other side (ie the side you cant get at) and there is also a screw down the bottom near the middle of the dash holding it in which i didnt know about and broke :oops:
Fuel cut off switch, were peugeot afraid of these pre multiplex 406s with their at the time new HDi engines doing diesel runaway on them :cheesy:
As for the rust situation, the boot floor is rusty because the boot didnt shut (it had an accident involving a skip and an icy road), its had water sitting in it which has corroded it, the sills are rotten most likely because the car was jacked up and the drainage holes blocked, but its not really a rust bucket, here is the rusty sills:
(hard to see but basically the sills have been half repaired and stone chip painted over but they didnt get through the MOT
Under the carpet in the rear passenger footwell there is a bit of rust that wouldnt take long before it is a hole:
The engine seems to run good, the battery is knackered, and there is a possibility the coolant got a bit hot at some point:
Nonetheless the plan is to continue taking off the parts, shout if there is anything that you need.
Bailes1992
Post by Bailes1992 »
Chuck the engine in yours.
It will have a lighter crank so will be a tad more revvy and gain an extra few MPGs!
Eh? I thought all the 2 litre HDis had the same crank (which started out in the 405 1.9 XUD and was still being used in the 508 last time I checked).
Bailes1992
Not quite! HDi90s had an XUD7 crank and HDi110s had an XUD9 crank.
Sonia406
Post by Sonia406 »
Nice 406, looking forward to more YT videos, I do enjoy watching your videos. :)
Miss Pug 2001 - 2023.
Bailes1992 wrote:Not quite! HDi90s had an XUD7 crank and HDi110s had an XUD9 crank.
405 SAUF RESTYL
DIESEL AND XU 0501 H1 (- XUD9A - XUD9 AND ANTIPOL EGR - XUD7)
405
DIESEL XUD9 0501 H1
TURBO DIESEL XUD9TE 0501 K7
406 D8
DIESEL TURBO XUD9SD 0501 H1
D9
DW10ATED TURBO DIESEL PARTICLE FILTER AND BVA OR DW10ATED TURBO DIESEL AND BVA 0501 K7
DW10ATED TURBO DIESEL AND BVM OR DW10ATED TURBO DIESEL PARTICLE FILTER AND BVM 0501 K7
TURBO DIESEL DW10TD AND BVM 0501 K7
TURBO DIESEL DW10TD AND BVM 0501 K7 (I guess one of these must be BVA)
508
DIESEL TURBO DW10BTED4 AND BVM 0501 K7
Pfft, it's better than gardening in the sun :(
