Niz406 wrote:
What electrical faults are you having then? How many things are going wrong?
These:
P1404 - ECU fault / Glow Plug Control Module/Relay
P1403 - Engine Coolant Heater (radiator fan !) Wiring fault/Fan Relay/ECU fault
P1408 - Engine Coolant Heater (rad fan) Control - Wiring/ECU fault/Battery
P0221 - Throttle Potentiometer (this could be an old code because this was changed last may at a Peugeot Dealer (famous for forgetting to reset the codes)
After discussing with Foggy, it seems I could have the common D9 fan relay problems, an incorrect voltage has got back to the ECU and brought the
Check Engine light on..... it's in on Thursday for the process of elimination on by one, might be a bit of faffing around but hopefully a simple fault (couple on new relays).
Then....... I've got an exhaust leak (90.00), clutch and flywheel (600.00?), a knock from the rear that's started (bush/droplink?), then
she needs 2 rear tyres (200.00)and an replacement exhaust flexible pipe (120.00)
I am sick of 8 year old cars at present, I am also feeling hard done to as I am working hard but I am the worst off financialy in my family...they've all got new cars, my old man has just retired and is loaded and could easily help me but doesn't offer (and i'm not f*cking asking either).
goes off to sit in a nice quiet place for a bit with cup of tea*
