its fully working, and is compatible with a multichanger (not included).
whats it worth?
whats my clarion cd player worth
- no2lurch
Current car - Ph3 1.8 306
- Bailes1992
Re: whats my clarion cd player worth
Do D9's have a standard ISO connection as standard like the D8's?
- mjb
- Site Admin
No. The D9 has 3 VAN bus pins wired to the BSI. Also, cars with the JBL amplifier carry line-level signals to the amp over the speaker linesBailes1992 wrote:Do D9's have a standard ISO connection as standard like the D8's?
- no2lurch
Which adaptor do I need to convert my d9 w reg Sri estate to iso plug?
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
I didnt need any adapter to convert my W reg 2000 GTX HDi, just a bit of jiggery pokery on the power side as pug have the switched (Ign)feed and permanent feed arse about face, swapped red for yellow as i remember and its all good, just plug and play
- DiscoPol
I think MJB is referring to the additional plug that is at top in the back of the Clarion head units with a few poxy little wires coming out of it, that is not standard iso,mjb wrote:No. The D9 has 3 VAN bus pins wired to the BSI. Also, cars with the JBL amplifier carry line-level signals to the amp over the speaker lines
but,
and i can only go from empirical research on this and claim to know nothing more than the fact i swapped mine out a month ago so can tell you that the lower two plugs are standard ISO plugs and go straight in to new stereos as i said probably have to swap over your power feeds but mine wasnt any trouble at all.
- mjb
- Site Admin
No, the D9 has VAN bus lines on the power connector where the lines for illumination, speed and something else should be. As also pointed out above, the perm and switched +12v lines are also swapped.Polskipug wrote:I think MJB is referring to the additional plug that is at top in the back of the Clarion head units with a few poxy little wires coming out of it, that is not standard iso, .mjb wrote:No. The D9 has 3 VAN bus pins wired to the BSI. Also, cars with the JBL amplifier carry line-level signals to the amp over the speaker lines
- DiscoPol
so its just plug and play as far the connectors go then?
all i had to do was swap the powers over and its all still working fine to date
