I then mashed up by hand badly as the puggy dealer who fitted my last oil filter thought he'd have a laugh and murdered the filter up real tight (thanks).
I also noticed my rear engine mount is completely detached at the 3 rubber cushions inside the main bush so god knows how that's hanging in there.
I had the car up on 2 trolley jacks on the sills (someone at work had lost the axle stands).
Whilst draining, the 4.5 ltrs of old oil plus 400ml of Forte flush for some reason would not fit in my 4 ltr butchered oil bottle (you know the sort) panic set in as the oil rose relentlessly as I quickly grabbed a container of Mrs Weltons, emptied its contents (girly hair stuff) and swapped it over into the stream of black stuff.
Luckily I had cardboard down but the spillage was nothing short of a mini Oil Tanker disaster, many many cloths were engaged in the mopping up excersize and I hadn't even got the new stuff in yet.
Well as I said, next time, someone else can change my oil I will have no problem paying someone to do it. If you've got the thing up on ramps it would be a lot easier and you could leave the tray in place.
I must say though that the Forte oil flush has left my new Silkolene engine oil absolutley clean
