Radio codes
mattie007
Radio codes
Post by mattie007 »
I cant find my radio code after taking the battery off for a recharge.
Is it possible to get hold of it without paying Peugeot a fortune?
Bertrum
Re: Radio codes
Post by Bertrum »
Im sure i read on here that the radios are not actually coded but instead are configured only to "talk" to the ecu in your car.
After a jump start or recharge it should work like normal.
2001 406 2.2 HDI Executive
Re: Radio codes
mattie007 wrote:A bit about the car. Its a 98 1.8 SX LE model, which my dad purchased new from Corby motors.
I don't think it's going to be that easy I'm afraid. Maybe it'd help to know which one it is.
Re: Radio codes
Bertrum wrote:Im sure i read on here that the radios are not actually coded but instead are configured only to "talk" to the ecu in your car.
That's D9s. The stereo in D8s needs a 4 digit code, and if you lose the code you're best off getting a replacement
Re: Radio codes
Can you post the radio's serial no?
I "found" a D8 radio decoder whilst trawling the net; don't know whether it works but it's worth a shot!
mattie007
Re: Radio codes
Post by mattie007 »
I'll take it out over the weekend and find out. Looks like I'll just get a new head unit though.
Re: Radio codes
Check the handbook and the service book - chances are it may well be written down there
It's also not uncommon to find the code written in permanent marker on the stereo itself
Re: Radio codes
mattie007 wrote:I'll take it out over the weekend and find out. Looks like I'll just get a new head unit though.
Do post the s/n here anyway, it'd be interesting to see if that tool works!
mattie007
Re: Radio codes
Post by mattie007 »
Will do. Should be sometime over the weekend.
I remember the code being printed on a credit card type security device. Cant find it anywhere though!
mattie007
Re: Radio codes
Post by mattie007 »
Right, the numbers I have are:
Model No: 22DC594/65B
Product No: FD0198381048534
Theres a third number aswell: 9022 215 94651
Does that help?
Re: Radio codes
The s/n should be 10 numbers apparently; I'll pop my radio out tomorrow as I know the code already & see which numbers generate the correct pin.
mattie007
Re: Radio codes
Post by mattie007 »
I cant see anymore numbers on it!
Re: Radio codes
It must be one of the ones you posted with a couple of numbers knocked off. I'll report back what I find out!
mattie007
Re: Radio codes
Post by mattie007 »
Yeh, I would say its the last number, 9022 215 94651, but without the 90?
Re: Radio codes
mattie007 wrote:Yeh, I would say its the last number, 9022 215 94651, but without the 90?
The code for that is 5466, hope it works!
