Is it easy to change the headunits over, as I've never had a built in stereo before. Also, am I gonna need some sort of adapter plate to fill the hole where the original stereo is? It all works perfectly, but I just want to put my mp3/dvd player in.
phil
Thinking of a new headunit.
- Captain Jack
Re: Thinking of a new headunit.
What's your car? Generally not a problem on Peugeots but you may run into obstacles trying to inteface the HU to the stalk control.
Also, may be an issue if you have a factory JBL amp in place (needs rewiring).
Yes mate you will need an adaptor plate (about a tenner ish) and if you want stalk control to work (as long as ytour new head unit has the facility) are about £30.
Fairly straight forward fit as there is quite a bit of room behind the standard radio to fit the extra wiring. But like said the only problem comes if you got the JBL amp
Eclipse Car Audio
http://www.eclipsecaraudio.co.uk
52 Reg 406 Rapier HDI estate
09 reg Vauxhall Astra Design 1.7 CDTI EFX
S Reg Ford Fiesta Van
