Ladies, Gents.
Anyone know the size of the front speaker mounts in my D8 estate?
I'm trying to collect everything I'll need before pulling off the door cards and installing. Laziness, would be an accurate description I guess.
I'd like to grab some MDF rings but unsure on thickness.
Then half a ton of deadening and amplifier wiring and we'll see what the standard speakers can handle.
Speaker mounts
- Nightshade
Speaker mounts
1.9 XUD, 97 estate
- Captain Jack
Re: Speaker mounts
it's the usual 6.5"/17cm speaker that's in there. Why do you need the rings there? They are screwed onto the door card, which is screwed onto the door (same set of screws).
Re: Speaker mounts
Stock speakers aren't much cop anyway, can get a pair of cheap aftermarket replacements for £20!
- Nightshade
Re: Speaker mounts
Exactly that. Ideally we want the most solid mount possible for speakers - actually concrete or even granite is the ultimate solution, but mdf is a bit cheaper and easier to work withCaptain Jack wrote:it's the usual 6.5"/17cm speaker that's in there. Why do you need the rings there? They are screwed onto the door card, which is screwed onto the door (same set of screws).
Lee, you'd be surprised what stock speakers can do. 90% of sound quality comes from your installation and 10% from the quality of the speakers.
Stocks on a good solid mounting, in a well deadened door with mass loaded vinyl on the inside skin and fed a healthy 50 watts or so from a decent amplifier will outperform many an expensive speaker that's been just swapped in.
1.9 XUD, 97 estate
