Radio Code
Radio Code
Mate's got a R reg 406 with coded radio but lost the card with
code on it . Am i right in thinking the code is buried in the
vin number , and if so does anyone know how to work it out ??
Re: Radio Code
Hi mate. Take the last 4 digits of the vin and use the 1234 method.
If last digits are 3651 for example, add a 1 to the 3, 2 to the 6, 3 to the 5, 4 to the 1.
This would be 4885, but as the pug only allows numbers 1 - 6 to be input, you will need to take '6' from any number over 6.
Code would be 4225.
Sounds complicated but really isn't..
Good luck.
( read this on a 306 forum, seems to work....
Code would be 4225.
Good luck.
Re: Radio Code
Just remembered, I think its the last 4 digits of the radio's serial number - not the VIN.
How did you get on?
How did you get on?
- DaiRees
- Site Admin
Re: Radio Code
Ah that info might come in useful cos I found an old stereo from my D8 in the attic the other day, but have no idea what the code is for it...GingerMagic wrote:Just remembered, I think its the last 4 digits of the radio's serial number - not the VIN.
How did you get on?
Re: Radio Code
Not tried it yet he's been taken into hospital , will let you know soon as .
Re: Radio Code
Keeping my fingers crossed for you, Lou......puggy wrote:Not tried it yet he's been taken into hospital , will let you know soon as .
Remember:
............Pugfest needs you!............
Re: Radio Code
I tried the 1,2,3,4 method but got no joy and then I found this forum: http://forum.legija.net/forum.php at 9.00 this morning. By lunchtime, they had the correct code for me. You will need the serial no. stamped on the stereo, and few other bits to get an accurate reply. Look for my posts and you'll see what they need.
1982 VW Polo C
1990 Pug 205 XE
1994 Renault 19
1998 Rover 218 SLX
2000 Citroen Xsara
2003 Vauxhall Vectra 2.0 LS DTI
2005 Mazda 6 S
2003 Mazda 6 Sport Diesel
1999 406 LX 1.8 Petrol
I also have a vague recollection of a silver Nissan Sunny and a red Proton somewhere way back before my brain got addled.
1990 Pug 205 XE
1994 Renault 19
1998 Rover 218 SLX
2000 Citroen Xsara
2005 Mazda 6 S
Re: Radio Code
Hi guy's
Is this for D8 models only or does it apply to fully muxed D9 models too, As I wasn't aware of any code being needed for my stereo
Cheers Paul.
Cheers Paul.
2006 BMW e61 535d m-sport
run's for cover
Re: Radio Code
think it's only for d8's my d9 doesn't need one ...
Re: Radio Code
puggy wrote:think it's only for d8's my d9 doesn't need one ...
Thanks puggy.
run's for cover
Re: Radio Code
so d9's dont have radio codes???
Re: Radio Code
No, D9s are coded to the car with PP2000. You can change your stereo with another factory fit unit but will need to get it ' coded ' with PP2000 so the cars ECU will talk to it..!!
Re: Radio Code
So if I put an after mrket in then wanted to put old back in that would be ok
Re: Radio Code
Yes, because the factory one is coded to the car already. There are lots of threads on here regarding aftermarket stereos....
