Auto volume
Auto volume
Is there an "auto volume" function on the jbl stereo systems,when i say "auto volume" i mean the volume increases or decreases according to road noise/speed.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: Auto volume
Yes, if you press the options button, it indexes through settings for bass, treble, loudness, fader, balance, then auto volume, (on/off). Adjust with the up/down buttons above/below the centre button.......
Re: Auto volume
I have that, doesn't do ef all as far as i can tell.
Re: Auto volume
I thought the auto-volume just adjusted the volume, so when stopping a quiet dodgy cassette - the radio didn't come on really load - it kinda softened the blow??
Mine is turned on, and I think all is does is occasionally being at full volume when turning stereo on....
Re: Auto volume
No, it increases the volume as road speed rises
Re: Auto volume
Okay - perhaps I should read the manual.....
Re: Auto volume
Well i've tried it in mine and it makes no noticeable difference at all,my o/h has a Focus and you can really tell the auto volume in that,does it have to be activated via pp2000?
- rwb
Re: Auto volume
I'm also convinced that nothing happens.
Certainly the number to which the volume is set does not change.
Moreover I cannot hear any difference.
Re: Auto volume
Mine definitely works, (checked this afternoon).
- rwb
Re: Auto volume
Does the number change?
Re: Auto volume
I don't think so, (didn't watch TBH).
Re: Auto volume
I enabled it with PP2000, but haven't noticed a difference. Do all Clarion HUs support this option?
Re: Auto volume
It works, but it doesn't really do much. The volume setting doesn't change, but the volume is slightly increased.
You can test it by switching it on and off while driving on the motorway.
2000 406 TS4 2.2 saloon
Re: Auto volume
If it's supposed to be on the bass/treble/fade-button then I don't have it - or it hasn't been enabled correctly. Any hints on getting it to work?
- rwb
Re: Auto volume
I believe it is on the bass/trebble/balance/... button.
I changed the curve from 0 to 5, but I can't tell any difference.
