Going to fit amp + sub with original HU, can be done?
Re: Going to fit amp + sub with original HU, can be done?
mate ill take some pics of my set up tomaz and post them i use 1 of these http://www.ebay.co.uk/itm/SPEAKER-TO-RC ... 3f04c2edac
So the problem is down to the converter i used ?
damn, i though mine would be better than those, at least it looked to be better than those...i was about to buy one of that but it looked cheap sh*t....
mine works fine ive got 2 amps running of it
hm... i have to investigate a bit what's going on .. i think the problem will be the converter because it needs it's own power(most of them doesn't require this) if you saw the schematics ... (to the 12V switched and a earth which means when ignition is switched on) ...but i will have to see if its connected to that cable ...
