Fitting aftermarket amp -with standard head unit ?
Anyone know how to fit an aftermarket Amp, using standard Headunit?
theres no pre-outs,
got a 10 disc changer so idont want to rip the the original head unit out,
How do iget the Aux -out, splice into speaker wires?
also where wouid iget the Rem-feed from ?
any ideas?
theres no pre-outs,
any ideas?
- Bailes1992
Re: Fitting aftermarket amp -with standard head unit ?
You can get Line to RCA converters.
http://www.caraudiodirect.co.uk/pacsoem ... erter.html
Then you can either use the trigger wire or run a switched + to the amp for a remote.
Cheers sam,
ive worked the pre-out part out,
but im working on where to get the trigger wire from,
carnt find any diagrams, of the pin outs, Nightmare,
- Bailes1992
What car?lozz wrote:Cheers sam,
If it's a standard ISO then look for the switched live pin.
If not then the Line to Preout converter above will make a trigger wire. As soon as it detects audi it will switch the Amp on.
Its a shitroen xsara, same wiring as pugs ithink,Bailes1992 wrote:What car?lozz wrote:Cheers sam,
iwill give it another go tomoz
thanks for the sugestions
- Bailes1992
You want to get a multimeter or a test blub. Ground one side out and look which pin is the ingition switched.
There is a ground, ingition, permenant and illumination usually.
Cheers sam,
ive just found a pin out diagram after much sifting through piles junk on the tinternet,
- jamjar1383
you can just use the live from the fag lighter, just splice into the wire so they will both work after.lozz wrote:Cheers sam,
dont that on my first 406 and worked a treat.
d9 hdi 90 rapier estate
iwill try that,jamjar1383 wrote:you can just use the live from the fag lighter, just splice into the wire so they will both work after.lozz wrote:Cheers sam,
thanks
- Bailes1992
Check your fag lighter is switched or permenant though! Mine is currentley permenant for instance.
