Putting a radio in
Putting a radio in
The Clarion tape player keeps making a loud pop noise when i go over bumps. What sort of alternative radios are available for the 406 that still allow the stalk to work, and is there any that display the station on the mfd or use the changer in the boot?
leestudd30
Re: Putting a radio in
Post by leestudd30 »
I think you can fit any aftermarket stereo but you will need a lead like this first:
http://www.connects2.co.uk/c2search.asp ... &modID=577
And the appropriate patch lead depending on the make of stereo you fit, like this:
http://www.connects2.co.uk/c2search.aspx?catID=115
You will probably need a fascia adapter like this too:
whats a good radio, something with bluetooth that can dial out, and works with an iPhone to stream music?
FarmerPug wrote:The Clarion tape player keeps making a loud pop noise when i go over bumps.
Resolder output transistors...
i don't see much dry solder on the radio, i did all the earthing solder that holds in the pcb to the frame, where is the output transistors, what do they look like?
An aftermarket radio seems to be a lot of work, if i could keep the thing standard that would be fantastic.
leestudd30
Depends how much your willing to pay really, this one does bluetooth and iphone:
http://caraudiosecurity.com/shop/produc ... 14443.html
Or this one:
http://caraudiosecurity.com/shop/produc ... 14725.html
And this one:
http://caraudiosecurity.com/shop/produc ... 14921.html
FarmerPug wrote:i don't see much dry solder on the radio, i did all the earthing solder that holds in the pcb to the frame, where is the output transistors, what do they look like?
There was a thread once but I'm pretty sure it got deleted. They'll be heavily screwed to the casing with heat paste.
ill get pictures of it at the weekend its sitting apart in the shed, that would be good to fix.
I have a few other clarions but the problem with them is they don't mix with the jbl amp the volume starts off too high.
Some Blaupunkt radios will work with the pugs wiring,
itried a Blaupunkt Digicalva, Travel pilot ithink it was called, that worked with the stalk,
ithink there like hens teeth to find tho, :(
blaupunkt radios are really good they are what mercs have i kept one out of my old merc a good solid radio but it is a bit too old with its casette player :cheesy:
i put an aftermarket radio into my fiat which came with the standard radio but that was broke, the one that went in was a waferdale bluetooth job which was good it had a full keypad for dialing, streamed music and the display was a dot matrix so it could display the track playing.
ill get a look at the clarion tonight for these transistors
Personal experience - Bluespot=overpriced junk. Mercs fit Becker, or at east they used to.
i thought the becker was for the top spec mercs they are good radios hard to get single din versions these days
The reason why imentioned blaupunkt,
is only because, its the only one ive found that works the stalk,
Quality??
its bland but does its job,
the Digicalva, has built in sat nav, if you can pick one up thats what id go for,
been looking for one for a few month now not many come up on ebay,
the sat nav disc for them is £150 :shock:
is that a digiciever, they look quite good from the pictures
how good is the sat nav i just see a black and white display does this do that screen comes out of the dash tricks?
its just a B&w display,
im sure its spelt, Digicalva.,
screen is on part of a flip off front theyre basic,
