What Head Unit?
trem1
Re: What Head Unit?
Post by trem1 »
got your pm, cant see that this helps but its the info for your car so might help in other way :)
Vehicle family 406 (RESTYLING)
Build code 08921 89 2 0364
Warranty Start Date 21/05/2001
Engine serial number 10 DYFU 40291***
Gearbox serial number 20 DL80 3233605
BER e2*98/14*0087*02
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 406 (RESTYLING)
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL SELECTION PACK
ENGINE TURBO DIESEL DW10TD
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EKQ - PAINT - WICKED RED
INTERIOR TRIM TYPE FOCH VELOUR + "NY" POINTIL
UPHOLSTERY COLOUR "FZ"
GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
ENGINE (TYPE) EW/DW
OTHER BADGE HDI
BADGE LX
Vehicle characteristics
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 22X18
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
SPEED SENSOR SIGNAL SENSOR HALL EFFECT
ENGINE (TYPE) EW/DW
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
EOBD SELF-DIAGNOSIS SYSTEM WITHOUT "EOBD" AUTO-DIAGNOSTIC
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 1 FAN 350W
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT W/O INJECTION VARIANT
Gearbox Transmission
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 77
WHEEL STYLE STEEL WHEEL
CLUTCH HYDRAULIC CLUTCH
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
DIFFERENTIAL (GEARBOX) SUPERIOR GEARBOX DIFF
TYRE (SIZE, TYPE) 195X65X15 H TYRES
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE GEARBOX BE4R
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 22
ANTI-THEFT DEVICE STANDARD ANTI-THEFT
FRONT ANTI-ROLL BAR FRONT ANTI ROLL BAR DIAM 24
SERVICE BRAKE ELECTRONIC BRAKEFORCE DISTRIBUTION
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
POWER STEERING FLUID COOLING SYSTEM WITH POWER STEERING OIL COOLING
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT VARIABLE SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
EMERGENCY BRAKING ASSISTANCE TEVES BRAKE SERVO
Body fittings
HORNS HORNS-HARMONY
AERIAL AMPLIFIED ROOF AERIAL
WIPER ARM FRONT BLADE WITHOUT DEFLECTOR
SIDE MOULDINGS (TYPE) PROTECTOR WITH CHROME RING
SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS L=50 + SIDE SILL
WHEEL EMBELLISHER (STYLE) 15 INCH JAZZ STYLE WITH 7 OPENINGS
SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT DOOR MIRROR WITHOUT ADDITIONAL FUNCTION
EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING BONNET SOUND-PROOFING
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
BUMPER BODY COLOUR FRONT/REAR BUMPER
MUDFLAP WITHOUT MUDGUARD
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES BODY COLOUR DOOR MIRRORS + HANDLES
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) DOMED DRIVER’S DOOR MIRROR GLASSS
REAR SCREEN WASH REAR SCREEN WASH
SUN ROOF FIXED ROOF
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) FIXED REAR QTR GLASS
WINDOW (TYPE) NON ATHERMAL WINDSCREEN
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN
REAR SEAT ARMREST WITHOUT REAR ARMREST
LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP
RADIO TELEPHONE WITHOUT TELEPHONE PRE-EQUIPMENT
LUGGAGE COVER WITH LUGGAGE COVER
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
AIR CONDITIONING WITH HEATER ASSISTED CONTROL
SPEED GRADUATIONS GRADUATION MPH
CONSOLE LONG CONSOLE (SEPARATE GLOVE BOX)
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
DASHBOARD EQUIPMENT DASHBOARD LARGE GLOVEBOX COVER, WALNUT EFFECT TRIM
INTERFERENCE SUPPRESSION RADIO INTERFERENCE SUPPRESSOR
MISC. INT. LAMPS MAP READING LAMP
LOAD SPACE TRIM TRIM BOOT + RR TAILGAT FLAP
INSTRUMENT PANEL (CHARACTERISTICS) STANDARD SPEEDO LOWER GRADUATION
DOOR TRIM WALNUT EFFECT DECOR
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS
RADIO CONTROLS REMOTE RADIO CONTROL WITHOUT CD FUNCTION
POLLEN FILTER WITH POLLEN FILTER
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT SUN VISOR SCREEN
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
FRONT SEAT ARMREST FITTED WITH ARMREST
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
HANDBRAKE WARNING LAMP WITHOUT PARKING BREAK INDICATOR
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT ELECT CONTR RR WINDOW LIFTER
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
COURTESY MIRROR DRIV OCCULT+PASS OCCULT W/O LIGHT
OIL GAUGE STD OIL LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG DOUBLE FRONT LATERAL AIRBAG
PASSENGER AIRBAG PASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION) DRIVERS SIDE ELECTRIC WINDOW AUTO STOP
LOUDSPEAKER GRILLE (REAR PASSENGER COMPARTMENT) WITHOUT REAR SHELF LOUDSPEAKER GRILLE
ON-BOARD COMPUTER COMPUTER
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
COURTESY LAMP FR+RE DOORS CONT - FR+RE INTERIOR LAMP
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SUN VISOR DRIVER’S+PASSENGER’S SIDE WITHOUT INSCRIPTION
RADIO RECEIVER "RD2" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARR+FR DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
AIR CON./TEMPERATURE REGULATION WITH REGULATION AIRCON/TEMP
STORAGE (OTHERS) TWO STORAGE BOXES IN BOOT
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
INTERIOR PROTECTION WITHOUT INNER PROTECTION
SWITCH ELECTRONIC ANTI-THEFT KEY
COOLANT LEVEL WARNING LAMP WATER LEVEL WARNING
ANTIPOLLUTION MALFUNCTION WARNING LAMP WITHOUT ANTIPOLLUTION MALFUNCTION LED
TRIM ADAPTATION STANDARD GEAR LEVER KNOB
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL RUBBER STEERING WHEEL,4 BRANCH
FAN 1 FAN 350W
Electrical
ALTERNATOR ALTERNATOR 150 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L2 400
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
MULTIPLEXING WITHOUT MULTIPLEXING
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION DEPOLLUTION
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
FIRST AID KIT WITHOUT FIRST AID BOX
TRAFFIC SIDE LEFT HAND DRIVE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 1 HF PLIP KEY + 1 SINGLE MAIN KEY
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
