Anyone know if the standard cd head unit will play cd-r's and what do I need to convert them to (tried .wav parked to cd compliant but no joy) cheers
PS If I can get a cd changer does it need to be coded for the car/head unit?
Ta again
Gaz Walker
Standard Head Unit & CD-R's
Re: Standard Head Unit & CD-R's
Mine plays cd's I've written myself, without any hassle.
I think V reg makes it a D9 (can't be asked to look it up again) so it'll need someone to tell the BSI it's got a changer. Mine plays CD-Rs. I tell Nero to burn the music as a music CD it's fine, if you stick them on there just using the browser as .wavs or worse mp3s it won't see them.
Cheers - going to stick with my bluetooth/mp3 headunit - problem is now - take key out and stereo stays on - swapped yellow and red wires - still no joy.... any ideas which is perm live for memory and which is power for stereo?? as all my settings go after switch off
Cheers
Cheers
does the headunit stay on constant ?
or go off after say 40 seconds ?
Sorted cheers - red went to 1st white - original red (unit side) went to purple which was live but buggered I think - switches off with key and remembers stations - but MFD went t1ts up before this - still displays info but no light - bulbs ok so no idea
