Stereo advice (please read first 3 replies too)
I have a 1997 3.0 V6 and wish to install an aftermarket stereo.
I have found many things in search but am unsure which things are all applicable to my car and so am asking here for difinitive answers from you guys in the know please.
Firstly, I would like to keep use of my stalk controls. I have seen leads but on websites a couple said not for the V6 model. Which lead do I need please and will it work with any stereo with a control input?
Secondly, I understand it may be possible to retain use of the radio display on the MFD? I'm a little OCD in that I hate to have a display not doing anything, so again what would I need for this and is it only compatible with Sony as I have read elsewhere? Also, if not connected I assume the MFD continues to show trip computer info, but is it just blank then on the left side?
Cheers
Cheers
Re: Stereo advice please
Ok so now I found that I'd need 2 leads for the stalk controls;
http://www.caraudiodirect.co.uk/ict-29- ... aptor.html
+ Plus lead specific for stereo, i.e. for an Alpine; http://www.caraudiodirect.co.uk/incarte ... aptor.html
Am I right in thinking that my car, being a D8 with Philips stereo, can't be connected to the MFD? It appears only later models with VDO/Clarion have a lead for this, unless anyone knows different?
Also, I see two facias available, one being 'rubber touch'. Which is better and why? Basically I just want the stereo to look in place with the rest of the console as possible.
Lastly, any recommendations for stereos? I want iPhone connectivity via USB and be great to be able to make handsfree calls using Bluetooth, but I guess most stereos have these functions now anyway?
I'm liking this one the Alpine CDE-126BT;
http://www.caraudiodirect.co.uk/alpine-cde126bti.html
Good connectivity and can illuminate in amber to help match the rest of the interior display.
Re: Stereo advice (please read my own replies too)
Im not 100% which kit you need is your car a d8 or d9 ?Coxy wrote:I have a 1997 3.0 V6 and wish to install an aftermarket stereo.
Cheers
Have alook at this
http://www.incartec.co.uk/assets/files/ ... eugeot.pdf
thats for a d9
if you look at the one on the site for d8 it says for those used without a screen its confusing as yours you say is a 97
airiel adapter you will need this http://cgi.ebay.co.uk/PC5-27-ISO-DIN-Ae ... 255d83296f
ithink this is the one you will need, : it might be worth sending them a message and asking them,
linky http://cgi.ebay.co.uk/PEUGEOT-406-806-S ... 43a014e042
also if you order one make sure you tell them which patch lead you need Eg Alpine /sony /kenwood etc,
if you dont they just send out the 1st patch lead they pick up,
Re: Stereo advice (please read 1st 3 replies too)
I'm new to 406's, but believe being a 1997 model mine's a D8 right? Someone please correct me if I'm wrong here.
what does the front grille look like?Coxy wrote:I'm new to 406's, but believe being a 1997 model mine's a D8 right? Someone please correct me if I'm wrong here.
is it honey comb with a big puggy badge ?
this is a d9
http://cgi.ebay.co.uk/2003-PEUGEOT-406- ... 20b7928655
this is d8
http://cgi.ebay.co.uk/1997-PEUGEOT-406- ... 27b93b08f9
d9 is just a facelift basicly theyre the same shell
Re: Stereo advice (please read first 3 replies too)
D8 for sure then.
It appears these both do the same job yet look different (if pics represent actual item) and are very differently priced.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT (patch lead included) £17.25
http://www.caraudiodirect.co.uk/ict-29- ... aptor.html (plus requires buying patch lead) £33.99 + £4.99
I assume they do the same thing and both are suitable for my car?
ithink the ebay one will be plug and play,Coxy wrote:D8 for sure then.
the other one ithink is abit of a rip off on price,
Theyl work the stalk but ithink the display of the radio will vanish you will just end up with just the temp display and the mpg etc,
icouid be wrong tho,
- Captain Jack
Correct.lozz wrote:Theyl work the stalk but ithink the display of the radio will vanish you will just end up with just the temp display and the mpg etc,
Also, the more expensive ones may be for the multiplex models of vehicles, which start from 2002. Completely different electronics there.
1. you can get the stalk to still work . it doesnt matter what engine you have ..
2. i dont know any reason why you would want to keep the radio display on your dash . the radio will have a nice bright lcd display
- Captain Jack
Engine, no. Whether the car is D8 or D9 and whether it's non-multiplex (pre-COM2000) or multiplex (COM2000) matters.Gary406 wrote:1. you can get the stalk to still work . it doesnt matter what engine you have ..
