My Kenwood mp3 HU works fine, however it will not come on when the ignition is turned on, nor will it switch off when the engine it turned off and the key removed from the ignition, you have to manually do it
Not a real hinderance, just a bit of a pain
I don't think the yellow and red wires need swapping around and the memory is fine
cheers for any info
