Subwoofer rebuild
Subwoofer rebuild
heya guys, i have recently noticed that my subwoofer is taking up far to much space ( had loads op probs getting the spare tyre out :p )
its a massive stock made box with everything built in , now my general idea was to take the subspeakers out ( there are two of them, of the inverted type)
i would then work them into seperate holders that i can put in each corner of the boot.
the amp i would then put between the back speakers .
if anyone has any ideas on how to do this , or what stuff to use ...(i'm not gonna spend loads on this) just want to have a decent sound and easier accesability ^^
any ideas are welcome
Re: Subwoofer rebuild
Perhaps email Dr Erkine from talkaudio.co.uk for a bespoke design?
[email protected]
[email protected]
[email protected]
[email protected]
IN8 wrote:Perhaps email Dr Erkine from talkaudio.co.uk for a bespoke design?
[email protected]
[email protected]
ok, cheers.
i have been sketching out a plan of my own. now also to find out what to use for material
keep the idea's comming
grtz
you cant just make the box smaller,, well you can but the speaker wont do its job properly
subwoofers need a certain sized box Cubic feet. so if its a pre made box its probably made to the specifications of the speaker and making a smaller box will probably not work as good
Gary406 wrote:you cant just make the box smaller,, well you can but the speaker wont do its job properly
yeah, oly problem is the shape of the box towards the boot of the 406 atm
you can buy pre built single 1 cubic foot boxes which will probably be ok
like this
http://cgi.ebay.co.uk/12-WEDGE-ROUND-SU ... 2557d83288
like this
i have this in my boot and i have loads of space left for shopping and to get the spare wheel out
these are 12inch each
this is a double 12inch box joined together think these boxes are about £50 made from 3/4 inch MDF
each side is 1 cubic foot
Gary406 wrote:i have this in my boot and i have loads of space left for shopping and to get the spare wheel out
these are 12inch each![]()
yeah, my one just hits the bottom of the top panel that supports the speakers mine are also a little smaller , i'll look up the specs and maybe get 2 single boxes , so i just disconnect and take out nice and easy
your probably best buying a double like mine altho for removing it will be easier having 2 singles due to the weight of a double
if you buy 2 singles off ebay dont pay double post charge
contact them tell them you wont pay double, you want combined postage
cos no doubt they will send it with a courier like DHL and its the same price for posting 2 as it is posting 1
thats were these sellers make cash ripping people off with post costs
i would take the 2 woofers out of the one i have nowGary406 wrote:if you buy 2 singles off ebay dont pay double post charge
here are the spec for my subwoofers, i have 2 of these (sorry for the german) currently the are set inverted into the stock box the came in
Sioux X2350 Woofer
Brutaler 30cm / 12" Subwoofer Chassis
Belastbarkeit : 1600Watt max.
Belastbarkeit : 360Watt RMS
Frequenzbereich: 21 Hz - 600 Hz
Kennschalldruck : 91dB
Impedanz: 4 Ohm
Langhub Foamsicke
verstärkte PP Membran
inverse Dustcape
massiver Aludruckgusskorb
Resonanzarm
Blauer Korb
Polkernbohrung mit Schutz
versilberte Schraubterminals
75mm Schwingspule
zusätzliche Belüftungsöffnungen
Außendurchmesser: 320mm
Einbauöffnung: 290mm
Einbautiefe: 163mm
Gesamttiefe : 190 mm
Gehäuse Empfehlung :
45Ltr. - 60Ltr. Bassreflex , BR Rohr 100mm x 140mm
VB1 : 29 Ltr. / VB2 33 Ltr. Bandpass, BR Rohr 2 x 100mm x 140mm
Sioux X2350 Woofer
Impedanz: 4 Ohm
Langhub Foamsicke
inverse Dustcape
Resonanzarm
Blauer Korb
75mm Schwingspule
Einbautiefe: 163mm
there are 3 different box types for car subwoofers
1.sealed
2.ported
3.bandpass
you have bandpass, what you need to do is find out what specs are needed for a sealed box ...
every woofer should have a specification for each of those 3 types
1.sealed
2.ported
3.bandpass
- Bailes1992
Why don't you just buy two single boxes? I have a single box in my Focus...
Get two of these...
http://www.caraudiodirect.co.uk/phonoca ... osure.html
Get two of these...
