How do you secure headunit into facia adapter
jason1987
Post by jason1987 »
i installed my ice today and put the facia plate thing in and theres nothing for the headunit to hold on to, what has everyone else done?
Re: How do you secure headunit into facia adapter
You should get a good fixing with the tabs on the head units slide in bracket, I did on my Kenwood set at any rate.
jason1987
Post by jason1987 »
so slide rhe cage into the facia, then bend back the tabs? it just looks like a drop tho into the dash
HimBigChief
Post by HimBigChief »
Install the surround, install the cage bending the tabs back to get it nice and tight, then pull all the wiring through the cage and attach to headunit, then slide headunit into cage.
Image Image
jason1987 wrote:so slide rhe cage into the facia, then bend back the tabs? it just looks like a drop tho into the dash
It will hold in there. There should be a lip that the HU sits against when it's in the fascia adaptor.
it should click in there, and the hu should come with release keys to get it out again
