Sat Nav Disc
gumby6371
Re: Sat Nav Disc
Post by gumby6371 »
Out of curiosity has anyone run a global test on a car with a naffed sat nav?
Mine gave the disc unreadable message so I removed the disc, later I noticed that on a global test it gives an open circuit fault on the sat nav.
This could be due to;
no disc being present
dirty/misaligned laser
or it might just be cream crackered.
I had to change the cd multi-changer when I got the car and suspect water ingress at some point in the cars history :(
pepro
Re: Sat Nav Disc
Post by pepro »
Thanks did not make myself clear.Its the sat nav unit in the boot
pepro
Re: Sat Nav Disc
Post by pepro »
I cannot remove it and all is undone!!! it seems stuck at the rear
pepro
Re: Sat Nav Disc
Post by pepro »
can anyone help please??
Re: Sat Nav Disc
There are some small holes in the front of the unit, just push a fine screwdriver in each one and pull the unit when screwdrivers are still pushed in the holes.
pepro
Re: Sat Nav Disc
Post by pepro »
Thanks a million,have seen the holes,will buy something "fine" to use to release it.
Re: Sat Nav Disc
You don't have to buy anything, look through your cupboards for some skewers or something. I've used the insides of a biro before, and a broken wire coat hanger.....
