yes i got jamjars kit theres lots in it and will be enough for what i want. the main amp doing most of the work will be the 3000w amp for the subs. the 600w amp will be powering 2 6x9s
its not a case of being a lot in it. you running 2 subs on 1 amp and 6x9s on the other amp.
not ideal using same power cable.
the subs will use alot of the power meaning the other amp for the 6x9s will probably not get enough flowing to it at high volumes
thats why its better to run 2 power cables so enough juice can flow to the amps.
what are the real watts of the amps ? the 3000watt amp . what RMS power is that ?
Gary406 wrote:its not a case of being a lot in it. you running 2 subs on 1 amp and 6x9s on the other amp.
if thats the case whats the point of Distribution Block's????
anyway im running 1100wrms in mine and that kit is plenty ample.
d9 hdi 90 rapier estate
so i wired up the amp today im only useing the 3000w amp i got 2 subs and 2 6x9s running off it and sounds real good very loud my only problem is the amp stops working when i turn it up to loud. when it cut out i thort the fuses blew but nope there both ok the only other thing im thinking is the ground isnt done very well im using the back seat mount when u fold down the back of the rear seat there is a small black bracket with 2 bolts ive taken off most of the paint for good connection i might have a loot and see if ive missed some paint thats stopping connection
defo a bad earth. i earth mine under the rear seat bolts. fold seats down and undo 1 bracket.
sand it to bare metal and bolt it under there. these bolts are solid tight
just dont screw the amp to the back of the seat tho cos the metal screws will touch the metal seat that the eart cable is bolted to
interference issues then
jasonfreeborn wrote:lol it all seems ok now dont know why it cut out like that but i will still sort the earth out to make sure
u got any pic's jase???
need to upload them to photobucket and then copy the img code in to the repley box on here
throw some prodigy in and watch the pannels in the car rattle
i'll let u know if i ever finish my build [/quote]
Ooh i have an amp like that, im a complete noob with audio. it came in a car i took in part ex a while ago. i have no idea how to fit it though
98, Executive turbo estate in aluminum silver. The stealth wagon! Now departed, New project Xsara VTR-8 in progress, Next Project, 406 D8 / JAP. So will be looking for a 406 again when the xsara is done!
