Hi folks,
I have recently taken a Sony CD multi-changer and head unit from my wife's old Corsa which has been sent to the scrapper. I took out the factory fitted Phillips in my Pug 406 but (excluding the aerial) there are four plugs on the Phillips and obviously none of them match the 16 pin socket on the back of the Sony. I presume I need an adapter harness to make the loom fit the Sony but can anyone advise me what the actual one is that I need?
Also, if I do make the switch, will I be surrendering the stalk functions or is there a dedicated loom that will tie in eveything?
Paddy
Wiring advice.
- 1.8 8v
Wiring advice.
1982 VW Polo C
1990 Pug 205 XE
1994 Renault 19
1998 Rover 218 SLX
2000 Citroen Xsara
2003 Vauxhall Vectra 2.0 LS DTI
2005 Mazda 6 S
2003 Mazda 6 Sport Diesel
1999 406 LX 1.8 Petrol
I also have a vague recollection of a silver Nissan Sunny and a red Proton somewhere way back before my brain got addled.
1990 Pug 205 XE
1994 Renault 19
1998 Rover 218 SLX
2000 Citroen Xsara
2005 Mazda 6 S
Re: Wiring advice.
Pop into a car audio shop-take the radio in with you and they will give you
What you need,
Have you left the Sony wiring loom in the corsa..by any chance.
Yes you will loose the ability to use the pug stalks.
What you need,
- 1.8 8v
Re: Wiring advice.
Cheers Lozz - the Corsa was crushed a few weeks back so no chance of rescuing anything there. It never occurred to me at the time.
1982 VW Polo C
1990 Pug 205 XE
1994 Renault 19
1998 Rover 218 SLX
2000 Citroen Xsara
2005 Mazda 6 S
1990 Pug 205 XE
1994 Renault 19
1998 Rover 218 SLX
2000 Citroen Xsara
2005 Mazda 6 S
- Nightshade
Re: Wiring advice.
Can't you use a patch lead to keep the pug stalk working?
That's what I was hoping to do - ebay has them for sony head units......?
1.9 XUD, 97 estate
Re: Wiring advice.
Nope .Nightshade wrote:Can't you use a patch lead to keep the pug stalk working?
You need a stalk adapter too,
Last time I looked they where expensive, not worth the hastle/money IMHO.
Re: Wiring advice.
The problem with harness adapters and patch leads is, although they work, they are massive and a bugger to tuck behind the stereo if you have limited space...
