How do you secure headunit into facia adapter
i installed my ice today and put the facia plate thing in and theres nothing for the headunit to hold on to, what has everyone else done?
- Site Admin & Mad Biker!
Re: How do you secure headunit into facia adapter
You should get a good fixing with the tabs on the head units slide in bracket, I did on my Kenwood set at any rate.
so slide rhe cage into the facia, then bend back the tabs? it just looks like a drop tho into the dash
- HimBigChief
Install the surround, install the cage bending the tabs back to get it nice and tight, then pull all the wiring through the cage and attach to headunit, then slide headunit into cage.
It will hold in there. There should be a lip that the HU sits against when it's in the fascia adaptor.jason1987 wrote:so slide rhe cage into the facia, then bend back the tabs? it just looks like a drop tho into the dash
it should click in there, and the hu should come with release keys to get it out again
